Softened potential well / potential step
In summary, the discontinuous potential well of length ##2L## has different energy eigenvalues than the differentiable version with a same depth.
hilbert2
Insights Author
605
TL;DR Summary
Approximating a finite potential step with a continuous function
Do any of you know of an article or book chapter that discusses the difference between a discontinuous potential well of length ##2L##
##V(x)=\left\{\begin{array}{cc}0, & |x-x_0 |<L\\V_0 & |x-x_0 |\geq L\end{array}\right.##
and a differentiable one
##\displaystyle V(x) = V_0 \exp\left[-\left(\frac{|x-x_0 |}{L}\right)^n\right]##
Edit: the correct equation above should have been
##\displaystyle V(x) = V_0 - V_0 \exp\left[-\left(\frac{|x-x_0 |}{L}\right)^n\right]##with ##n## some large but finite exponent (limit ##n\rightarrow\infty## is equivalent to the discontinuous version) ?
There was one article discussing the non-classical reflection of a wave packet at a downward potential step that considered the difference between these: https://aapt.scitation.org/doi/abs/10.1119/1.3636408
It should be possible to handle the difference between these two as a small perturbation, if the energy eigenstates and eigenvalues of the discontinuous basic potential well are already known (at least if ##V_0## isn't a very large or infinite number). Doing this for a 2D or 3D well of some shape would be more involved.
Shouldn't the sign inside the exponential be positive? It looks to me like the negative sign, in the limit ##n \to \infty##, gives a "downward step", but the potential well you define is an "upward" step.
It becomes a well if ##V_0<0##
The exponential does, but the discontinuous version doesn't; it's a "downward step" if ##V_0 < 0##. So they're still not the same.
I didn't look at the article (no access) only at the two potentials in post #1.
Don't think it very likely an exponential yields an analytical solution ...
Oh, sorry, it was supposed to be like
##\displaystyle V(x) = V_0 - V_0 \exp\left[-\left(\frac{|x-x_0 |}{L}\right)^n\right]##.
The reflection from downward potential step was just an example of an article that discusses the effects of making an initially sharp potential barrier continuous and differentiable. I'm mostly interested on the effect of this on the energy eigenvalues of a finite-depth potential well.
Edit: the problem has been studied in these two articles I found:
https://www.scielo.br/pdf/rbef/v42/1806-9126-RBEF-42-e20190222.pdf
https://iopscience.iop.org/article/10.1088/0953-4075/45/10/105102
The first is about the general problem and the second one specifically about modelling the confinement of an atom inside a fullerene cage.
Related to Softened potential well / potential step
1. What is a softened potential well?
A softened potential well is a type of potential energy function that describes the behavior of a particle in a certain region of space. It is characterized by a gradual decrease in potential energy towards the center, rather than a sharp drop-off as in a traditional potential well.
2. How is a softened potential well different from a traditional potential well?
In a traditional potential well, the potential energy abruptly changes from a high value to a low value at the edge of the well. In a softened potential well, the potential energy gradually decreases towards the center, resulting in a smoother transition.
3. What are some real-life examples of softened potential wells?
Softened potential wells can be found in various physical systems, such as the gravitational potential well of a galaxy, the electric potential well of a charged particle in a dielectric material, and the potential well of a particle in a liquid or gas. They can also be artificially created in experiments using optical or magnetic traps.
4. What is a softened potential step?
A softened potential step is a type of potential energy function that describes the behavior of a particle when it encounters a sudden change in potential energy. It is characterized by a gradual increase or decrease in potential energy, rather than a sharp jump as in a traditional potential step.
5. How is a softened potential step different from a traditional potential step?
In a traditional potential step, the potential energy abruptly changes from one value to another at the edge of the step. In a softened potential step, the potential energy gradually increases or decreases towards the edge, resulting in a smoother transition.
  • Quantum Physics
  • Classical Physics
