Soil Mechanics - Shear Stress in a Soil Sample
In summary: For Test B:The line connecting the center of the circle (600, 0) to the point where the circle intersects the x-axis (2550, 2550) has a slope of 1. Therefore, the angle between the failure plane and the x-axis is: θ = tan^-1(1) = 45°.E. Determine the orientation of the major principal plane at failureThe major principal plane is perpendicular to the line connecting the center of the circle to the point where the Mohr circle intersects the y-axis.For both tests, the major principal plane is parallel to the x-axis, therefore, the orientation is 0°.
rstewart8
Two consolidated and drained (CO) triaxial compression tests (tests A and 8)
were conducted on dense dry sand at the same void ratio. Test A had a cell
pressure of 150 kPa, while in test B the cell pressure was 600 kPa (u=OkPa).
These stresses were held constant throughout the test. At failure, they had
maximum principal stress differences of 600 and 2550 kPa, respectively. You
are asked to:
a) Plot the Mohr circles for both tests at initial conditions and at failure.
b) Determine shear strength of this soil.
c) Determine the shear stress on the failure plane at failure for both tests?
d) Determine the orientation of the failure plane in each specimen (use
equations or graphical solution).
e) Determine the orientation of the major principal plane at failure.
f) Determine the orientation of the plane of maximum shear stress at failure
g) If these soil samples were tested in direct simple shear, would the soil
exhibit compression or dilation?
IMG_0971[/url[/B]
] by Ryan Stewart, on Flickr
<< Fixed up image by Mentors >>
B. Determine the Shear Strength of the Soil
τ = (Ơ1 - Ơ3)/2 Sin(2θ)
=(2550)/2 * Sin (66.4 *2)
=935.5 KPa
C. Determine the shear stress
Sample B
θ = 45 + ∅/2
=45 + 42.8/2
θ=66.4
Cos∅ = Ơn/r
Ơn = Cos∅ x r
= Cos (180-2θ) x 1875
= 1273.95 KPA
τ = c + Ơn tan (2θ)
= 0 + 1273.95 x tan (2 x 66.4)
= 1375.7 KPA
This is as far as I've gotten just wanted to make sure I was on the correct path before continuing.
Thanks for any help!
A. Plot the Mohr circles
Initial conditions:
Test A: (150, 0), (600, 0)
Test B: (600, 0), (2550, 0)
At failure:
Test A: (600, 600), (2550, 0)
Test B: (2550, 2550), (2550, 0)
B. Determine the shear strength
The shear strength of the soil can be calculated using the Mohr-Coulomb equation:
τ = c + Ơn tan ∅
Where:
τ = shear strength
c = cohesion
Ơn = normal stress on the failure plane
∅ = angle of internal friction
For Test A:
Ơn = (150 + 600)/2 = 375 kPa
∅ = tan^-1(600/600) = 45°
c = 0 (given in the question)
Therefore, the shear strength for Test A is:
τ = 0 + 375 x tan(45°) = 375 kPa
For Test B:
Ơn = (600 + 2550)/2 = 1575 kPa
∅ = tan^-1(2550/600) = 76.87°
Therefore, the shear strength for Test B is:
τ = 0 + 1575 x tan(76.87°) = 2550 kPa
C. Determine the shear stress on the failure plane at failure for both tests
For Test A:
The shear stress on the failure plane is equal to the maximum principal stress difference, which is given in the question as 600 kPa.
For Test B:
The shear stress on the failure plane is equal to the maximum principal stress difference, which is given in the question as 2550 kPa.
D. Determine the orientation of the failure plane in each specimen
The orientation of the failure plane can be determined using the Mohr's circle. The failure plane is perpendicular to the line connecting the center of the circle to the point where the Mohr circle intersects the x-axis.
For Test A:
The line connecting the center of the circle (150, 0) to the point where the circle intersects the x-axis (600, 600) has a slope of 1. Therefore, the angle between the failure plane and the x-axis is:
Related to Soil Mechanics - Shear Stress in a Soil Sample
1. What is shear stress in a soil sample?
Shear stress in a soil sample refers to the force per unit area that is required to cause the soil to slide or deform along a certain plane or surface. It is a measure of the resistance of the soil to shear forces.
2. How is shear stress measured in a soil sample?
Shear stress in a soil sample can be measured using a shear box test, where a soil sample is placed in a box and subjected to a constant force until it reaches a state of failure. The force required to cause failure is then divided by the cross-sectional area of the sample to determine the shear stress.
3. What factors affect shear stress in a soil sample?
Several factors can affect the shear stress in a soil sample, including the type and composition of the soil, the moisture content, the density, and the confining pressure. Additionally, the presence of any structural elements, such as roots or rocks, can also influence the shear stress.
4. How does shear stress impact the stability of a soil sample?
Shear stress plays a crucial role in determining the stability of a soil sample. If the shear stress exceeds the shear strength of the soil, it can cause the soil to fail and lead to slope instability, landslides, or other types of geotechnical failures.
5. How can shear stress be controlled or mitigated in a soil sample?
To control or mitigate shear stress in a soil sample, various methods can be used, such as reinforcing the soil with materials like geotextiles or geogrids, increasing the soil density, or altering the moisture content. Additionally, proper slope design and drainage can help to reduce shear stress in a soil sample.
