Solar Cell connection to DC load
In summary: B000NIKIOK?ie=UTF8&camp=1789&creative=9325&linkCode=as2&tag=thehackernews-20&linkId=3N0G3KVHGX2KWZ [Working]
techguy
Dear all,
i am possible to do experiment on the application of solar cell and i have run into several problems so i need to seek advice from all the experts in here. I have several DC loads include:
1 x Cooler fan (12V, 0.25A)
1 x cooler fan (12V, 0.2A)
2 x rechargable AA size battery (each 1.2V 0.20mA)
1 x handphone (the charger of the phone reads output to be DC 5.3V and 0.4mA)
The spec of the solar.. under sunlight the voltage reading is around 22-23V and current around 0.25A.
I cut the wire of the charger and attached it to the solar cell and try to charge the phone. The phone reads charging but after 5 secs it says stopped charging. May i know what is wrong? will a DC to DC converter solve this problem? But the best DC to DC converter that i can find from supplier the output is 5V and 1A. Will it still works?
My next question will be if i will to do connection to the 2 cooler fan, will it be better if i connect it in parallel or series?
Is it possible to do multiple connections with the above DC loads?
Do you all think that it will be possible to connect the solar cell in series with anyone of the cooler fan, the 2 AA size battery and then to the handphone in series?
Any recommendations on how should i connect if i want to do multipe connections?
Thank you for your time in reading my questions and offering your help. So sorry, i lack knowledge in such stuffs but was allocated this project thus very desperate for help with experts in this forums. Thank you so much everyone. Really appreciate it.
I think you need to do a little bit of background reading about voltage and current.
Try wikipedia.
I'm surprised you haven't destroyed the phone.
You will certainly destroy (possibly explode) the AA battery.
Try wikipedia.
hmmm.. i tried but i find it hard understanding.. i understand what u mean what u say.. but is there any advice that you can give with regards to my problem?
You need to supply your solar panel voltage (23V??) into regulators, which are not 100% efficient, for each voltage that your other devices call for in their spec. Then you use parallel connections from these regulators so that all devices get the same voltage on that node. You must make sure you don't draw more current/power than your solar panels can supply also . .
If you connect all of the devices in series you're asking for trouble, you got to use KVL and circuit analysis to understand this. Also, it looks like your solar panels can't supply nearly enough power that you would need to power the devices from the device specs you've given
The best advice is to STOP doing that, until you do as mgb_phys says, and learn more about voltage and current and power, and other basic concepts. You cannot (and should not) just go cutting wires and splicing things together to see what happens. You could get yourself hurt that way, and you certainly can start a fire that injures others.
Do some reading at wikipedia.org, and consider getting yourself a beginning textbook in electronics. You can also buy simple electronics kits to help you start to learn the basics of electronics, and to get some relatively safe experience in building your own electronics projects. Like these:
http://www.transeltech.com/kits/kits1.html
Related to Solar Cell connection to DC load
1. How does a solar cell connect to a DC load?
The solar cell is connected to a DC load through a series connection, where the positive terminal of the solar cell is connected to the positive terminal of the DC load, and the negative terminal of the solar cell is connected to the negative terminal of the DC load.
2. Can multiple solar cells be connected to a single DC load?
Yes, multiple solar cells can be connected in parallel to increase the current output, or in series to increase the voltage output. This allows for more efficient use of the solar cells and better power output to the DC load.
3. What type of connector is used to connect the solar cell to the DC load?
The type of connector used will depend on the specific solar cell and DC load being used. However, common connectors used for solar cells include MC4 connectors and Anderson Powerpole connectors.
4. How do you ensure a secure and stable connection between the solar cell and DC load?
To ensure a secure and stable connection, it is important to use proper connectors and cables that are designed for outdoor and high voltage use. It is also important to regularly check and maintain the connections to prevent any loose or corroded connections.
5. Can a solar cell be connected to an AC load?
Yes, a solar cell can be connected to an AC load, but it requires additional components such as an inverter to convert the DC power from the solar cell into AC power for the load. This is commonly used in residential and commercial solar power systems.
  • Electrical Engineering
