Solar Heat Gain Factor table for southern latitudes
The discussion centers on the absence of Solar Heat Gain Factor (SHGF) data for southern latitudes in ASHRAE tables, which primarily cover northern latitudes. Participants suggest that solar gain should theoretically be similar for corresponding latitudes in the north and south, with adjustments for azimuth and seasonal differences. Calculating solar gain involves reversing latitude signs and adjusting building orientation, while also considering factors like insolation loss at low sun angles and local cloud cover statistics. Additionally, outdoor temperature data is crucial for estimating conductive heat gain and loss. The conversation highlights the need for more comprehensive resources for southern latitude solar gain calculations.
francismann
TL;DR Summary
SHGF tables provided by ASHRAE only includes north latitudes, the cooling load for the building I am designing for is in the south latitude.
Hello! Despite being a mechanical engineer I'm fairly new to building science. I'm looking to compute for solar heat gains in a building somewhere down south. ASHRAE SHGF tables only lists data for north latitudes and there's no mention of the south latitude. May I ask why there isn't any on the south and if there is, where can I find it? Many thanks!
I am not a building engineer or even a mechanical engineer, but if solar gain alone is about the heat gain from the influx of sun light over a period of time at a given latitude, then I would expect this gain to be equal for same latitude north and south, with the north and south direction swapped in case direction (azimuth) is relevant.
@francismann
Welcome to PF.
I would change the sign of the latitude to place it in the Northern Hemisphere, rotate the building aspect by 180°, and change the date to correct the seasons by adding or subtracting six months. The apparent path, followed by the Sun during the day, would be reversed about solar noon, since East is West, and West is East, and never the twain will meet. (Rudyard Kipling, misquoted).
https://en.wikipedia.org/wiki/The_Ballad_of_East_and_West
For Solar position see post: https://www.physicsforums.com/posts/6959658
From there, you calculate the angle of incidence on the surfaces to determine the insolation energy on each surface.
Depending on your requirements, you may want to account for the additional insolation loss by the longer air path at low Sun angles.
You will also need cloud cover statistics (often available on a regional basis).
Outdoor temperature records were generally available for locations near enough to be useful in calculating conductive heat gain/loss; this was calculated hourly for one day in each month of a year, and multiplied by days in each month for monthly subtotals.
If I recall correctly, the hourly outdoor temperatures had to be estimated/interpolated. The daytime temperature curve roughly resembled a sine wave with the peak around mid afternoon. The nighttime temperature is mostly a straight line drifting down to the daily low shortly before Sunrise.
Cheers,
Tom
(Irrelevant note: This was done to meet the energy efficiency requirements in the California Building Code [Title 24] for residential, commercial, and industrial buildings.)
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
22K
