Solid formed by rotating equilateral triangle.
In summary, the problem involves determining the surface area and volume of a solid formed by rotating an equilateral triangle of side a about its base. The equation for surface area is found to be (pi.root3.a^2)/2, while the volume of revolution is (pi.a^3)/4. However, the equation for y= sqrt(3) * x only works for values of x from 0 to a/2, causing the volume of revolution to be incorrect and resulting in the correct answer for surface area to be (pi.root3.a^2)/2.
Mo
81
Determine the surface area and volume of a solid formed by rotating an equilateral triangle of side a about its base.
----------working out surface area--------
Integral of 2.pi.y dx with limits of a and 0.
I worked out; y = root3 . x
therefore surface area = root3.pi.a^2.
---------volume of revolution---------------
integral of pi.y^2. dx with limits of a and 0.
y = root3.x
therefore volume of solid formed = pi.a^3
I hope someone can check my answer to the first part (working out surface area) and then tell me where i went wrong with the volume of revolution.
The answer for the second part (volume of revolution) should be (pi.a^3)/4
Thanks.
Pretty close. The problem is with your equation y= sqrt(3) * x
I was working out the problem myself and was going to use symmetry, integrating from 0 to a/2, and multiply the answer by 2. This is when I noticed that your equation for y only works for values of x from 0 to a/2. i.e. the angle remains 60 degrees, and x keeps increasing. However, after a/2, the value of y starts decreasing.
Yes, that's true. So now i have worked out the value of surface area for half of the triangle and found that to be (pi.root3.a^2)/4
For the whole triangle, this value ahs to be multiplied by 2 surely?. Therefore final answer = (pi.root3.a^2)/2
The thing is, the answer i got given for this (first) part of the question was (pi.root3.a^2).
What else am i misssing in the solution?
Thanks for your help.
FAQ: Solid formed by rotating equilateral triangle.
What is a solid formed by rotating an equilateral triangle?
A solid formed by rotating an equilateral triangle is a three-dimensional shape created by rotating an equilateral triangle around an axis. This shape is called a cone.
How is a solid formed by rotating an equilateral triangle different from a regular cone?
A solid formed by rotating an equilateral triangle is different from a regular cone in that its base is an equilateral triangle rather than a circle. This results in a shape with a pointed vertex and a flat, triangular base.
What are the properties of a solid formed by rotating an equilateral triangle?
The properties of a solid formed by rotating an equilateral triangle include having one curved face and one flat face, and having a pointed vertex and a triangular base. It also has a circular cross-section and a constant diameter throughout the shape.
What are some real-life examples of a solid formed by rotating an equilateral triangle?
Some real-life examples of a solid formed by rotating an equilateral triangle include traffic cones, ice cream cones, and megaphones. These shapes are also commonly found in architecture, such as in the design of towers and spires.
How is a solid formed by rotating an equilateral triangle used in mathematics and engineering?
A solid formed by rotating an equilateral triangle is used in mathematics and engineering to demonstrate concepts related to geometry, such as rotational symmetry and volume calculations. It is also used in the design of various structures, such as bridges and buildings, to distribute weight and maintain stability.
