chosenone
- 183
- 1
In oder for atoms to become a solid they have to get closer to each other,to become a solid,as they are forced away from one another they become liquids,farther they become gas,and when thet become plasma the atoms kick the electrons out of there shell and wpn't let them rebond.this can be explained quit simply.the atoms as they get hotter to become a gas,or colder to become a solid,change there eloectromagnetiuc field strengths.the hotter they get to less their positive field is and the more their negative field becomes.so the outer electron repel against the surrounding atoms electron thus forcing them apart creating gases,as they are super heated the negative field of the neutron,or the lessing positive field of the proton is not enough to keep the electrons in orbit.on the down side,as the electrons fields decrease as the atoms get colder,the negative field of the electrons reduce allowing the atoms to get closer to each other thus giving it thye ability to become a solid,be this hypothesis i believe one can deduce that absolute zero can't be achieved.when the atoms electrons field becomes to small,even though the positive field of the proton increases to keep the electrons in orbit,if the electrons fields becomes zero the and if the neutrons have a negative field giving it the ability to bond with the proton,with a 2 positive to one negative in the nucleus with the one electron to make it neutral,the atoms would fly apart,and that can't happen,so the two fields of the atoms increase and decrease do to heat or cold changing the fields either way,to makes matter be a solid,liquid,gas or plasma!
