Solid of revolution about an oblique axis of rotation
In summary, the conversation discusses the method of using the disk method to find the volumes of solids of rotation when the axis of rotation is neither horizontal nor vertical. The method involves finding the area and volume using integrals, and applying it to a simple example. The conversation also suggests the idea of writing a tutorial on finding the curvature or radius of curvature of a function. The questions raised in the conversation revolve around the rotation and projection of $dD$ onto $y=mx+b$.
MarkFL
MHB
13,288
Hello MHB,
As students of calculus, we are taught to find the volumes of solids of rotation obtained by revolving given regions about horizontal and vertical axes of rotation. But, what if the axis of rotation is neither horizontal nor vertical? Please consider the following diagram:
We wish to revolve the region shaded in green about the line $y=mx+b$. Using the disk method, where the radius of a disk is $r$ and its thickness is $du$, we may write:
\(\displaystyle dV=\pi r^2\,du\)
Using the formula where the point is $(x,f(x))$ and the line is $y=mx+b$, we have:
\(\displaystyle r=\frac{\left|f(x)-mx-b \right|}{\sqrt{m^2+1}}\)
To find $du$ in terms of $dx$, let $dD$ represent the arc-length along $f(x)$ corresponding to $dx$, as in the following diagram:
https://www.physicsforums.com/attachments/1399
From this, we obtain:
\(\displaystyle dD=\frac{dx}{\cos(\theta)}\)
Now, to obtain the projection of $dD$ onto $y=mx+b$, we find that by rotating everything by \(\displaystyle -\tan^{-1}(m)\), we may write:
\(\displaystyle du=dD\cos\left(\theta-\tan^{-1}(m) \right)\)
Hence, we obtain:
\(\displaystyle du=\frac{\cos\left(\theta-\tan^{-1}(m) \right)}{\cos(\theta)}\,dx\)
Using the angle difference identity for cosine, we find:
\(\displaystyle du=\frac{\cos\left(\theta\right)\cos\left(\tan^{-1}(m) \right)+\sin\left(\theta\right)\sin\left(\tan^{-1}(m) \right)}{\cos(\theta)}\,dx\)
\(\displaystyle du=\left(\cos\left(\tan^{-1}(m) \right)+\tan(\theta)\cos\left(\tan^{-1}(m) \right) \right)\,dx\)
Using:
\(\displaystyle \cos\left(\tan^{-1}(m) \right)=\frac{1}{\sqrt{m^2+1}}\)
\(\displaystyle \sin\left(\tan^{-1}(m) \right)=\frac{m}{\sqrt{m^2+1}}\)
\(\displaystyle \tan(\theta)=f'(x)\)
we then obtain:
\(\displaystyle du=\left(\frac{1}{\sqrt{m^2+1}}+\frac{m}{\sqrt{m^2+1}}f'(x) \right)\,dx\)
\(\displaystyle du=\frac{1}{\sqrt{m^2+1}}\left(1+mf'(x) \right)\,dx\)
And so we may now give the area $A$ of the shaded region as:
\(\displaystyle A=\int_{x_i}^{x_f} r\,du=\int_{x_i}^{x_f}\left(\frac{\left|f(x)-mx-b \right|}{\sqrt{m^2+1}} \right)\left(\frac{1}{\sqrt{m^2+1}}\left(1+mf'(x) \right)dx \right)\)
\(\displaystyle A=\frac{1}{m^2+1}\int_{x_i}^{x_f}\left|f(x)-mx-b \right|\left(1+mf'(x) \right)\,dx\)
And the volume $V$ of the solid of revolution is:
\(\displaystyle V=\pi\int_{x_i}^{x_f} r^2\,du=\pi\int_{x_i}^{x_f}\left(\frac{\left|f(x)-mx-b \right|}{\sqrt{m^2+1}} \right)^2\left(\frac{1}{\sqrt{m^2+1}}\left(1+mf'(x) \right)\,dx \right)\)
\(\displaystyle V=\frac{\pi}{\left(m^2+1 \right)^{\frac{3}{2}}}\int_{x_i}^{x_f} \left(f(x)-mx-b \right)^2\left(1+mf'(x) \right)\,dx\)
Let's apply this to a simple example. Let's rotate $f(x)=x^2$ about the line $y=x-1$ on $[0,1]$.
The area of the region is:
\(\displaystyle A=\frac{1}{2}\int_0^1\left|x^2-x+1 \right|(1+2x)\,dx\)
Because \(\displaystyle x^2-x+1>0\) for all real $x$, we may write:
\(\displaystyle A=\frac{1}{2}\int_0^1\left(x^2-x+1 \right)(1+2x)\,dx\)
Expanding the integrand, we have:
\(\displaystyle A=\frac{1}{2}\int_0^1 2x^3-x^2+x+1\,dx\)
Applying the FTOC, we find:
\(\displaystyle A=\frac{1}{2}\left[\frac{1}{2}x^4-\frac{1}{3}x^3+\frac{1}{2}x^2+x \right]_0^1=\frac{1}{2}\left(\frac{1}{2}-\frac{1}{3}+\frac{1}{2}+1 \right)=\frac{1}{2}\cdot\frac{5}{3}=\frac{5}{6}\)
The volume of the solid of rotation is:
\(\displaystyle V=\frac{\pi}{2\sqrt{2}}\int_0^1\left(x^2-x+1 \right)^2(1+2x)\,dx\)
Expanding the integrand, we obtain:
\(\displaystyle V=\frac{\pi}{2\sqrt{2}}\int_0^1 2x^5-3x^4+4x^3-x^2+1\,dx\)
\(\displaystyle V=\frac{\pi}{2\sqrt{2}}\left[\frac{1}{3}x^6-\frac{3}{5}x^5+x^4-\frac{1}{3}x^3+x \right]_0^1=\frac{\pi}{2\sqrt{2}}\left(\frac{1}{3}-\frac{3}{5}+1-\frac{1}{3}+1 \right)=\frac{\pi}{2\sqrt{2}}\cdot\frac{7}{5}= \frac{7\pi}{10\sqrt{2}}\)
Excellent tutorial, Mark! Clear, concise, and above all, interesting... (Yes)Just a though, mind, and it's a bit 'niche', as it were, but have you considered writing a little tutorial about how to work out the curvature, or radius of curvature of a function...?
It's a bit cheeky of me to ask, I'll grant you that (lol), but you do these things so well [sincerity].All the best! :D
Gethin
Hi Mark! Very nice and clear derivation. Just a few questions:
$$\displaystyle du=dD\cos\left(\theta-\tan^{-1}(m) \right)$$
Why do we rotate by $-\tan^{-1}(m)$? And how does this obtain the projection?
FAQ: Solid of revolution about an oblique axis of rotation
What is a solid of revolution about an oblique axis of rotation?
A solid of revolution about an oblique axis of rotation is a three-dimensional shape that is formed by rotating a two-dimensional curve around an axis that is not perpendicular to the plane of the curve.
What is an oblique axis of rotation?
An oblique axis of rotation is an axis that is not perpendicular to the plane of rotation. This means that the axis is tilted or slanted in relation to the curve being rotated.
What are some examples of solids of revolution about an oblique axis of rotation?
Some common examples of solids of revolution about an oblique axis of rotation include cones, cylinders, and ellipsoids. These shapes are formed by rotating a line, circle, or ellipse around an axis that is not perpendicular to the plane of the curve.
What is the difference between a solid of revolution about an oblique axis and a solid of revolution about a perpendicular axis?
The main difference between these two types of solids of revolution is the orientation of the axis of rotation. In a solid of revolution about an oblique axis, the axis is tilted or slanted, while in a solid of revolution about a perpendicular axis, the axis is perpendicular to the plane of rotation.
What is the importance of studying solids of revolution about an oblique axis of rotation?
Studying solids of revolution about an oblique axis of rotation is important for understanding and analyzing three-dimensional shapes and their properties. It also has practical applications in fields such as engineering, physics, and architecture, where these shapes are commonly used in designs and calculations.
