Solid of revolution -- General question
In summary, when integrating a function bounded by a curve, there are two ways to approach it - either integrating with respect to x or with respect to y. The formulas will be different, but the end result will be the same. This applies to both finding areas and calculating volumes of solids of revolution.
0kelvin
50
There are two ways to revolve, around Y or X and the formulas are different.
If I have something bounded by $$f(x) = x^2 + 1$$. I can write $$x = \sqrt{y - 1}$$. But, is it wrong to swap axis to show that I'm integrating dy, not dx?
Mathematics news on Phys.org
The boundaries matter, and different integration directions lead to different formulas (but the same result).
Consider a simpler two-dimensional example. What is the area between your f(x), the x and y-axis and x=1? Well, it is ##\int_0^1 f(x) dx = \frac{3}{2}##. What if we want to integrate over y? f(x) changes from 1 to 2 but our area starts at y=0, so we set up ##\int_0^2 ? dy##. The function we need to integrate over is the length between (f(x) OR x=0) and x=1 in the horizontal axis, the length is 1 for y<1 and ##1-x(y) = 1-\sqrt{y-1}## for y between 1 and 2. To avoid using a case structure let's split the integral in two parts: ##\int_0^1 1 dy + \int_1^2 (1-\sqrt{y-1}) dy##. If you calculate that you should get the same result as before, ##1+\frac 1 2 = \frac 3 2## - but it was way more messy.
The same applies to the solids of revolution. You can integrate over the volume in any order you want, but some are more convenient.
Related to Solid of revolution -- General question
What is a solid of revolution?
A solid of revolution is a three-dimensional shape created by rotating a two-dimensional curve or shape around a fixed axis. This results in a shape that is symmetrical about the axis of rotation.
What are some examples of solids of revolution?
Some common examples of solids of revolution include spheres, cones, cylinders, and tori (doughnut-shaped objects).
How can I calculate the volume of a solid of revolution?
The volume of a solid of revolution can be calculated using the disk method or the shell method. The disk method involves slicing the shape into thin disks and adding up their volumes, while the shell method involves slicing the shape into thin shells and adding up their volumes. Both methods require knowledge of calculus and the formula for the volume of a cylinder.
What is the importance of solids of revolution in mathematics?
Solids of revolution have many practical applications in mathematics, physics, and engineering. They can be used to model real-world objects such as bottles, pipes, and gears. They also have important theoretical applications in calculus and geometry, as they help to illustrate concepts such as integration and symmetry.
Can solids of revolution be non-symmetrical?
Yes, it is possible for a solid of revolution to be non-symmetrical if the curve or shape being rotated is not symmetrical or if the axis of rotation is not in the center of the shape. In these cases, the resulting solid will have a distorted or asymmetrical shape.
  • General Math
