Solid state physics fermi surface
In summary: N-1/(2π/a)^3)N = (2/3) * (π/a)^3 * (N/(2π/a)^3)N = (2/3) * (π/a)^3 * (N-1/(2π/a)^3)N = (2/3) * (π/a)^3 * (N/(2π/a)^3)In summary, to calculate the atomic ratio of Zn to Cu in a ZnCu alloy at which the Fermi surface touches the first Brillouin zone faces, we can use the free-electron model and assume that the lattice constant does not change with Zn doping. By considering the FCC lattice of Cu and the Brill
asdf12345
Some atoms in Cu crystal (Cu has a FCC lattice) are replaced by
Zn atoms. Taking into account that Zn is bivalent, while Cu is monovalent,
calculate the atomic ratio of Zn to Cu in ZnCu alloy at which the Fermi
surface touches the first Brillouin zone faces. Use the free-electron model and assume that lattice
N/A
I would like some help getting started on this problem. Any help is much appreciated thank you very much!
Hello,
To solve this problem, we will use the free-electron model and assume that the lattice constant does not change with Zn doping. In this model, we treat the electrons in the crystal as a free electron gas. The Fermi surface is the boundary between the filled and empty states in the energy band diagram.
First, let's consider the FCC lattice of Cu. In this lattice, each Cu atom has 12 nearest neighbors. In order to replace one Cu atom with a Zn atom, we need to remove one electron from the system. This means that the total number of electrons in the system has decreased by one.
Now, let's look at the Brillouin zone. In the FCC lattice, the first Brillouin zone is a cube with each side having a length of 2π/a, where a is the lattice constant. Since we are assuming that the lattice constant does not change with Zn doping, the size of the Brillouin zone remains the same.
Next, we need to determine the number of Zn atoms in the system. Since Zn is bivalent, for every one Zn atom, we have two electrons. Therefore, the number of Zn atoms is equal to the number of electrons removed from the system.
Now, we can use the formula for the number of electrons in a Fermi sphere to determine the atomic ratio of Zn to Cu at which the Fermi surface touches the first Brillouin zone faces.
N = (2/3) * (π/a)^3 * (N/V)
Where N is the number of electrons, V is the volume of the system, and a is the lattice constant.
Since we are only considering the first Brillouin zone, the volume of the system is (2π/a)^3. Therefore, the number of electrons in the Fermi sphere is equal to:
Where N is the total number of electrons in the system.
Since we know that the number of electrons in the system has decreased by one, we can write:
Now, we can substitute this expression for N into our original equation and solve for the atomic ratio of Zn to Cu:
N = (2/3) * (π/a)^
FAQ: Solid state physics fermi surface
1. What is a Fermi surface in solid state physics?
A Fermi surface is a three-dimensional representation of the boundary between occupied and unoccupied electronic energy states in a solid material. It shows the allowed energy levels for electrons in a material at absolute zero temperature.
2. How is the Fermi surface related to the electronic properties of a material?
The shape and size of the Fermi surface determine the electrical and thermal conductivity, as well as other electronic properties, of a material. This is because the Fermi surface represents the energy levels available for electrons to move and interact within the material.
3. How is the Fermi surface calculated or measured?
The Fermi surface can be calculated using theoretical models and calculations based on the electronic band structure of a material. It can also be measured experimentally through techniques such as angle-resolved photoemission spectroscopy (ARPES) and de Haas-van Alphen (dHvA) effect measurements.
4. Can the Fermi surface change under different conditions?
Yes, the Fermi surface can change under different conditions such as temperature, pressure, or external magnetic fields. This can lead to changes in the electronic properties of a material, making it an important factor to consider in solid state physics research.
5. What are some practical applications of understanding the Fermi surface?
Understanding the Fermi surface is important in various fields such as materials science, condensed matter physics, and electrical engineering. It can help in the design and development of new materials with specific electronic properties, as well as in the optimization of electronic devices such as transistors and semiconductors.
