Solids and Liquids in Kinetics and Equilibrium
In summary: Concentration of reactant solid doesn't affect the reaction rate- Surface area doesn't affect the reaction rate
UMath1
361
I just now read in my textbook that solids and liquids are not included in equilibrium expressions, are they included in rate laws? If not, why? Would a greater molar amount of solid or liquid increase the rate of reaction? And why isn't surface area included in Rate Laws?
Also, for the equilibrium expression I understand that the concentration of a pure liquid or solid remains constant but why does it that means it has no bearing on k? Why doesn't increasing the concentration of a reactant solid increase the forward rate of reaction?
Chemistry news on Phys.org
What's the natural logarithm of one?
* * *Hi Bystander, I was writing my reply as yours came up. I hope you don't mind my going for a more didactic / lengthy explanation. * * *
@UMath1 : Here's a simple way of looking at this; see also the caveat below.
Suppose that A and B can react in a solvent X to form C.
A is a solid and is only partially soluble in X (solubility = S), whereas B is completely soluble.
If the reaction is bimolecular, the reaction rate (mol/L of C formed per unit time) will be proportional to the product of the concentrations of the two reactants:
r = k * [A] * [B]
As long as there is solid A, its concentration in X, i.e. in the phase/solvent where the reaction takes place will be constant and = S. Therefore:
r = k * S * [B] = k' * [B]
If you add more A, S won't change, so the reaction shouldn't change rate. The reaction rate is independent of the number of moles of A.
I think this addresses your main point of why the concentration of an undissolved solid or liquid 'in itself' doesn't affect the rate.
You need to consider the concentrations in the phase where the reaction takes place.
Your other point about the surface area is subtler.
Suppose you want to react NaHCO3 with an aqueous solution of HCl.
If you throw finely powdered NaHCO3 into the acid, you'll get a very fast reaction.
If you throw in the same mass of NaHCO3, but in the form of a compact, solid block, it will react overall much more slowly.
Still, the solubility of NaHCO3 in water is the same.
The reason why the first reaction is faster is that a finely subdivided solid dissolves faster than a compact block of the same solid.
So here you're looking at two consecutive kinetic processes: 1) dissolution of NaHCO3 into H2O and 2) reaction between HCO3- and HCl.
As you know, a sequence of reactions can only be as fast as the slowest one.
In the second case, the solid block takes more time to dissolve, thus slowing down the overall sequence.
I'm sure physical chemistry experts can give you even better examples, and I seem to remember there are cases, in catalysis for instance, where reactions occur in a special phase between liquid and solid, and there indeed I believe the surface area should be taken into account in the rate law.
Surface area is definitely important. Dissolving Zn in an acid will be much faster in the case of a large surface sheets than in the case a sphere.
Why we don't care? Because typically we deal with the same form of the reagent, so the difference is small (but in some cases it matters and should be taken into account).
Why it doesn't matter for the equilibrium then? Because surface area changes BOTH forward and backward reaction in exactly the same way, so their ratio stays constant.
FAQ: Solids and Liquids in Kinetics and Equilibrium
What is the difference between solids and liquids in kinetics and equilibrium?
Solids and liquids behave differently in kinetics and equilibrium due to their physical properties. Solids have a fixed shape and volume, and their particles are tightly packed, making it difficult for them to move. Liquids, on the other hand, have a fixed volume but can change shape, and their particles are more spread out, allowing them to move more freely.
How does temperature affect the behavior of solids and liquids in kinetics and equilibrium?
Temperature plays a crucial role in the behavior of solids and liquids in kinetics and equilibrium. An increase in temperature causes the particles in a solid or liquid to gain more energy, making them move faster and increasing their kinetic energy. This can lead to an increase in the rate of a reaction or a shift in equilibrium towards the side with fewer moles of gas.
Can solids and liquids participate in chemical reactions?
Yes, solids and liquids can participate in chemical reactions. In some cases, they may be the reactants or products, while in others, they may serve as a catalyst to increase the rate of a reaction. The state of a substance does not determine its ability to participate in a chemical reaction.
How do solids and liquids affect the rate of a reaction?
The physical state of a substance can affect the rate of a reaction. In general, solids and liquids have a lower rate of reaction compared to gases due to their tightly packed or spread-out particles. However, if a solid or liquid is finely divided or has a larger surface area, it can increase the rate of a reaction by providing more opportunities for collisions between particles.
What factors can affect the equilibrium between solids and liquids in a system?
The equilibrium between solids and liquids in a system can be affected by changes in temperature, pressure, and concentration of reactants and products. These changes can shift the equilibrium towards the side with fewer moles of gas or towards the side with a lower energy state, depending on the specific conditions. Additionally, the presence of a catalyst can also affect the equilibrium by lowering the activation energy and increasing the rate of the reaction.
