Solubility of chlorophyll and carotenoids
  • Thread starter Puchinita5
  • Tags
    Solubility
In summary, the conversation discussed a chromatography experiment with spinach leaves and the separation of pigments on chromatography paper. The results showed that carotenoids are less polar and more soluble than chlorophylls. However, in a subsequent experiment using a mixture of ethanol and pigment with petroleum ether, the chlorophyll separated into the petroleum ether while the carotenoids separated into the ethanol. The question was raised about why a non-polar pigment like carotene would dissolve more readily in a polar substance like ethanol rather than a non-polar substance like petroleum ether. The discussion also touched on the presence of natural surfactants in plant tissues and the structure of chlorophyll compared to a typical surfactant.
Puchinita5
183
okay. so i did a chromotography experiment with spinach leaves. A line of pigments separated from the spinach leaves was put on the chromatography paper. Then the paper was put in petroleum ether.
It showed carotene at the top, followed by xanthophylls, then chlorophyll A, then chlorophyll B. Therefore, I concluded that the carotenoids are less polar than the chlorophylls and is more soluble than chlorophylls.
THEN, and this is what makes no sense to me, we mixed a solution of ethanol and pigment with petroleum ether, shook it, and two layers formed. A dark dark layer and a yellowish layer. The p.ether was said to be at top because it was less dense.
WHY does chlorophyll separate into the p.ether while the carotenoids separate into the ethanol , whereas in the first experiment it was the other way around?! I would expect that the chlorphyll would dissolve more easily in ethanol and the carotenoids would separate into the petroleum ether.
i guess i could also ask the question, why would a non-polar pigment such as carotene dissolve more readily in a more polar substance (ethanol) rather than in a more non-polar substance (petroleum ether).
Carotene is known to http://pubs.acs.org/doi/abs/10.1021/ja01326a056" in plant tissues.
Remember that these essential oils and oily pigments are present in plant tissues which is an aqueous environment. Is it likely that water-insoluble compounds like carotene exist in pure form or as microemulsions associated with natural surfactants in plant tissues? How about in your extraction?
Compare the structure of chlorophyll with that of a typical surfactant. Do you see a non polar tail and a polar head?
Related to Solubility of chlorophyll and carotenoids
What is the solubility of chlorophyll and carotenoids?
The solubility of chlorophyll and carotenoids depends on various factors such as the solvent used, temperature, and pH. Generally, chlorophyll is more soluble in polar solvents such as methanol and ethanol, while carotenoids are more soluble in nonpolar solvents like hexane and acetone.
How does temperature affect the solubility of chlorophyll and carotenoids?
Temperature can significantly affect the solubility of chlorophyll and carotenoids. In general, solubility increases with an increase in temperature, as the molecules have more energy to overcome intermolecular forces and dissolve in the solvent. However, some carotenoids may have a decreased solubility at high temperatures due to the breakdown of their chemical structure.
What is the role of pH in the solubility of chlorophyll and carotenoids?
The solubility of chlorophyll and carotenoids is also influenced by the pH of the solution. At low pH, these molecules tend to be more protonated and less soluble in water. On the other hand, at high pH, they become deprotonated and more soluble. Therefore, the optimal pH for maximum solubility may vary depending on the specific chlorophyll or carotenoid compound.
How does the solubility of chlorophyll and carotenoids affect their bioavailability?
The solubility of chlorophyll and carotenoids plays a crucial role in their bioavailability, which refers to the extent to which they can be absorbed and utilized by the body. Generally, more soluble forms of these compounds are more bioavailable, as they can dissolve in the body's fluids and be transported to target tissues for absorption.
What techniques are commonly used to measure the solubility of chlorophyll and carotenoids?
Various techniques can be used to measure the solubility of chlorophyll and carotenoids, including spectrophotometry, chromatography, and turbidimetry. These methods involve measuring the absorbance or change in optical properties of the solution as the compounds dissolve. Other techniques, such as solubility tests and phase solubility diagrams, can also be used to determine the solubility of these compounds in different solvents and conditions.
21K
11K
  • Electrical Engineering
  • Quantum Interpretations and Foundations
14K
