Solubility of Sodium nitrate and nitrite
  • Thread starter Thread starter Tas_T
    Solubility
The discussion centers on the solubility of sodium nitrate (NaNO3) and sodium nitrite (NaNO2), with a focus on the reliability of available data. It is noted that while literature suggests NaNO3 is slightly more soluble than NaNO2, practical experiments show NaNO3 crystallizing out first during separation processes. This raises questions about the accuracy of solubility data, particularly in highly concentrated mixtures where ionic strength can affect solubility behavior. Participants highlight that solubility values typically apply to single compounds and may not be applicable in mixtures. The conversation also touches on the idea that in solutions with similar solubility, the compound present in higher concentration may remain in solution longer, although this is not guaranteed. Overall, the discussion emphasizes the complexities of solubility in concentrated solutions and the potential for unexpected outcomes in crystallization processes.
Tas_T
Hi, I wonder if anyone can share some info in regards to the reliability of the data that's available on the internet about the solubility of NaNO3 and NaNO2.
Everything I've found so far seems to point towards the nitrate being slightly more soluble than the nitrite and yet, when trying to separate a mixture of the two it looks like the nitrate is always the first to crystalize out .
Yes , I have been tested the crystals after every crystallization and most definitely the nitrate is crushing out while the concentration of the nitrite in the mother liquor is increasing after each crystallization.
I'm a bit confused. If anyone could help would much appreciate it .
Chemistry news on Phys.org
Solubilities listed are for solutions containing a single compound, not a mixture, plus these are very highly concentrated solutions, with very high ionic strengths, so it is quite unlikely they will follow simple "linear" models.
As a rule of thumb - if the amount of dissolved substance is comparable with the amount of solvent (as in: not orders of magnitude lower) things are almost guaranteed to go awry.
Likes symbolipoint and Tas_T
Thanks for the reply.
So, could it be that if the compounds have similar solubility the one with higher concentration is likely to stay in solution ? I mean at least to a point ?
Gotta test that thought . . .
"Likely" is too strong a word, more like "anything can happen" (definitely including the case where the higher solubility compound doesn't crash out first).
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
