Solubility Product, finding molar concentration
In summary, the molar concentration of the NaIO3 solution can be calculated by using the given information and the Ksp value for Cu(IO3)2. The concentration of [IO3-] in the solution is found to be 0.118M. The 2:1 ratio between NaIO3 and 2IO3- only applies when calculating moles, not the concentration.
Ace.
52
If the 2.0 x 10-5 mol of Cu(IO3)2 can dissolve in 2 L of NaIO3, find the molar concentration of the NaIO3 solution. Ksp = 1.4 x 10-7 for Cu(IO3)2.
Let y = [IO3-(aq)] present in the solution from NaIO3 Cu(IO3)2(s) ↔ Cu2+(aq) + 2IO3-(aq)
I [itex]\:\:\:\:[/itex] excess [itex]\:\:\:\:[/itex] 0 [itex]\:\:\:\:\:\:\:\:\:\:\:\:\:[/itex] y
C [itex]\:\:\:\:[/itex] -x[itex]\:\:\:\:\:\:\:\:\:[/itex] +1x10-5 [itex]\:\:\:\:[/itex] +2x10-5
E [itex]\:\:\:\:[/itex]excess [itex]\:\:\:\:[/itex] 1x10-5 [itex]\:\:\:\:[/itex] y + 2x10-5
Ksp = [Cu2+][IO31-]2
1.4 * 10-7 = [1.0 * 10-5][y + 2.0 * 10-5]
y = 0.118M
That is the correct answer but I am wondering why you don't divide by 2, since isn't 2IO3- in 2:1 ratio with NaIO3? I'm just totally confused when to use the ratios and when not to (like in this case).
But you are calculating [IO3-], not twice that.
Likes 1 person
So the only situation the 2:1 ratio applies is if I was trying to find moles?
Moles of what?
As a scientist, you are correct in questioning the use of ratios in this problem. In this case, the ratio of 2:1 for IO3- to NaIO3 does not apply because we are not looking at the overall reaction between NaIO3 and Cu(IO3)2. We are only concerned with the solubility product (Ksp) of Cu(IO3)2, which is a measure of the equilibrium between the solid Cu(IO3)2 and its dissociated ions in solution. Therefore, the ratio of 2:1 does not factor into the calculation of the molar concentration of NaIO3.
In general, ratios are used to determine the stoichiometry of a chemical reaction, but in this case, we are not looking at a reaction between two substances. We are looking at the solubility of one substance in a solution. So, we only need to consider the concentration of the ions from the dissociation of the solute (Cu(IO3)2) in the solvent (NaIO3).
I hope this clarifies why the ratio is not used in this calculation. Keep up the good work in your studies!
FAQ: Solubility Product, finding molar concentration
What is solubility product?
Solubility product is a measure of the maximum amount of a substance that can dissolve in a given solvent at a specific temperature. It is represented by the equilibrium constant Ksp and is used to determine the solubility of a compound in a solution.
How is solubility product calculated?
Solubility product is calculated by multiplying the concentrations of the ions in a saturated solution at equilibrium. This can be represented by the equation Ksp = [A+]^a [B-]^b, where A+ and B- are the ions of the compound and a and b are their respective coefficients in the balanced chemical equation.
How is molar concentration related to solubility product?
Molar concentration is directly related to solubility product. It is the measure of the number of moles of a substance per liter of solution. In the equation Ksp = [A+]^a [B-]^b, the concentrations of the ions are represented by their molar concentrations, making it an important factor in calculating solubility product.
How does temperature affect solubility product?
Temperature has a significant effect on solubility product. As temperature increases, the solubility of a substance also increases, leading to a higher solubility product. This is due to the fact that higher temperatures provide more energy for the molecules to overcome intermolecular forces and dissolve in the solvent.
What factors can affect the solubility product of a compound?
The solubility product of a compound can be affected by various factors such as temperature, pressure, pH, and the presence of other solutes. Changes in these factors can shift the equilibrium of the solution, ultimately affecting the solubility product and the solubility of the compound.
