Solutes with very high melting points
In summary, the conversation discusses the search for solutes with high melting points, particularly for the purpose of creating complex internal structures. The mention of metal oxides and ceramic core materials are suggested as potential options, with the latter being commercially available and able to dissolve in specific etchant mixes. These materials are commonly used in the lost wax process for casting components such as turbine blades.
rppearso
204
Does anyone know of any solutes (such as sodium chloride) that have VERY high melting points (preferably 1800C or higher)? They don't have to be water soluable but they need a solvent that can disolve them.
Chemistry news on Phys.org
Likes rppearso
Have you looked at metal oxides ? Alumina in particular has a very high melting point and can be made into colloidal suspensions and dissolved by acids ?
Likes rppearso
very awesome, thank you. Trying to machine a substance to form another molten material around and then be able to disolve it away so I can make complex internal structures that would be incredibly expensive to machine.
You need ceramic core materials for that . These are commercially available as either cement like materials which can be moulded or as solid blocks which can be machined . They will dissolve away in special etchant mixes . Different etchant mixes are made so that depending on which metal you are casting the core will etch away preferentially to the metal .
These ceramic core materials are essentially the same ones as are used for the moulds when casting components like Nimonic turbine blades by the lost wax process .
Likes rppearso
Related to Solutes with very high melting points
1. What is the definition of a solute with a very high melting point?
A solute with a very high melting point is a substance that has a melting point that is significantly higher than room temperature, typically above 1000°C.
2. What types of substances can have very high melting points?
Substances with strong intermolecular forces, such as ionic compounds and covalent network solids, tend to have very high melting points.
3. What factors contribute to a solute having a very high melting point?
The strength of intermolecular forces, the size and symmetry of the molecules, and the presence of multiple bonding interactions all contribute to a solute having a very high melting point.
4. How are solutes with very high melting points used in various industries?
Solutes with very high melting points are commonly used in industries such as metallurgy, ceramics, and electronics for their strength, durability, and ability to withstand high temperatures.
5. Can solutes with very high melting points also have high solubility in liquids?
Yes, solutes with very high melting points can still have high solubility in liquids, as their melting point only indicates their solid state behavior and not their solubility in a liquid solvent.
  • Classical Physics
11K
  • Chemistry
  • Chemistry
