Solution 1. order differential equation
In summary, the conversation is about finding all solutions to a first order differential equation of the form y'(t) + p*y(t) = y(t)^2. The person has tried to rewrite it to match the general form, but is struggling because the function is raised to the second power. They have attempted to use the general solution but it still includes the function itself, which should not be the case. The conversation also briefly touches on the use of µ(x) and the possibility of a Bernoulli differential equation.
santais
So I've been given an assignment to find all solutions to the differential equation as mentioned below. From what can be seen, it's a 1. order differerential equation.
The assignment is as stated:
[itex]
y'(t)+p*y(t)=y(t)^2
[/itex]
So I tried to rewrite to somehow match the general form of a 1. order differential equation:
[itex]y'(x) +p(x)y = q(x)[/itex]
But no matter what I try, I can't get it to look somehow like it.
The problem is that it equals the funktion itself raised in 2. I just have no idea how to find the solution, when that is the case. I tried to rewrite and solve it, using the general solution, but no matter what, the function itself becomes a part of the solution, which shouldn't be the case.
Been using the general solution as mentioned below:
[itex]e^{-µ(x)} * ∫e^{µ(x)} q(x)dx[/itex]
where [itex] µ(x) = ∫p(x)dx [/itex]
and [itex] µ(x) = px [/itex]
"e^{-µ(x)} * ∫e^{µ(x)} q(x)dx,µ(x) = ∫p(x)dx,µ(x) = px" You said µ(x)=px, but p is a function of x, so I believe it's something else. Also I think you meant not the first order since the original diff. equ is already of first order but of first degree.
FAQ: Solution 1. order differential equation
What is a "solution" in the context of a first-order differential equation?
A solution to a first-order differential equation is a function that satisfies the equation when it is substituted into the equation.
How is a first-order differential equation different from other types of equations?
A first-order differential equation involves a function and its first derivative, while other equations may involve different variables or higher derivatives.
Can all first-order differential equations be solved analytically?
No, not all first-order differential equations have analytical solutions. Some may require numerical methods or approximations to find a solution.
How many initial conditions are needed to find a unique solution to a first-order differential equation?
One initial condition is needed for first-order differential equations, as the solution can be found by integrating the equation once.
What is the significance of a first-order differential equation in science and engineering?
First-order differential equations are used to model many physical phenomena, such as population growth, chemical reactions, and electrical circuits. They are also important in solving more complex differential equations and in understanding the behavior of systems in nature.
