Solution for 2nd ODE Question 2d2ydx2 + 4 dydx+ 7y = e^−x cos x
  • Thread starter Thread starter song90
    Ode
The discussion revolves around solving the second-order differential equation 2y'' + 4y' + 7y = e^(-x)cos(x). The original poster successfully found the complementary solution (yc) but struggled with the particular solution (yp) due to uncertainty about the appropriate form for yp. Suggestions included using yp = e^(-x)(Acos(x) + Bsin(x)) and clarifying that if e^(-x) or cos(x) were solutions to yc, a modified form would be necessary. Ultimately, the correct particular solution was identified as yp = (1/3)e^(-x)cos(x), but the poster was confused about their earlier calculations.
song90
i solved the equation for yc. but couldn't solve for yp as i dint know what kind of undetermined method to put for yp, particular integral.
Your equation would be more readable as
2y'' + 4y' + 7y = e-xcos x
For your particular solution, try yp = e-x(Acos x + Bsin x).
Try e^-x (A*cos x + B*sin x)
do e-x there put a constant?
let say p=Ce-x(Acos x + Bsin x)
hi song90! :smile:
you can absorb the C into the other two constants
ie Ce-x(Acos x + Bsin x) = e-x(ACcos x + BCsin x),
so just rename AC A and BC B :wink:
sorry, i am new to this forum...
yp = Ce-x(Acos x + Bsin x). insert a constant at e-x since it is one of the members of undetermined coefficient?
2y'' + 4y' + 7y = e-xcos x <this is the original question and the answer for yp is 1/3(e-xcos x). Still i could not manage to get the ans for yp. Looking for help..
thanks for immediate reply. i was trying to solve the equations but i still couldn't get the answer for yp which is 1/3(e-xcos x). Wondering where the mistakes i had made
i'm not following you :confused:
(and anyway, it makes no difference, as i said before)
that's A = 1/3, B = 0, why couldn't you get it?
show us what you've tried :smile:
okay looked back on my workings i found that i had timed a "x" in the yp equation,
yp=(e-x(ACcos x + BCsin x))x. i was thinking yp had common with yc as
yc=e-x(Asin√(5/2)+Bcos√(5/2))
sorry, I've no idea what you're doing :confused:
put y = e-x(Acos x + Bsin x)
into 2y'' + 4y' + 7y = e-xcos x
to find A and B
i was told by lecturer (maybe i misunderstanding what she said). If yp has the common with yc, yp=(equation)x. something like this... I have no idea about this lor.
anyways thanks a lot for your help.
i think she meant that if e-x or cosx was a solution for yc (in this case, it isn't),
then you would need to use xe-x(Acosx + Bsinx) instead of just e-x(Acosx + Bsinx) :smile:
Yes, I think the OP was trying to say this.
  • · Replies 52 ·
