Solution for a first-order differential equation
In summary, the conversation is about determining two solutions for a given first-order IVP and solving it through integration. The person makes a few errors in their attempt and is asked to check for any division by zero and redo the integration step.
toni556
determine by inspection at least two
solutions of the given first-order IVP
dy/dx = 3y2/3
y(0)=0
2. Equations:
integral xa dx= xa+1/(a+1)+constant
change its form to 1/y2/3 dy/dx =3
integrate both sides with respect to x
then it will be
1/y2/3 dy = 3dx
now integrate to get y1/3/(1/3)=3x+c
for y(0)=0 then c=0
then y1/3/(1/3) =3x then y=x3
Is that right? does I miss any condition or jumped over some steps?
toni556 said:
integrate to get y1/3/3 =3x+c
A couple of errors there. Write 1/y2/3 as ya. What is the integral ya.dy?
toni556 said:
then y1/3/3 =3x then y=x3
That's wrong too, but happens to cancel one of the earlier errors.
Thanks I corrected them (it was only typing error)
That corrected one of the errors in the integration step. One remains. As I suggested, rewrite 1/y2/3 in the form ya before trying to integrate it.
You are asked for two solutions. Whenever you divide by an expression, what should you check for? At what step did you do a division?
FAQ: Solution for a first-order differential equation
What is a first-order differential equation?
A first-order differential equation is a mathematical equation that relates the rate of change of a function to the function itself. It involves only one independent variable and its first derivative.
What is the general form of a first-order differential equation?
The general form of a first-order differential equation is dy/dx = f(x,y), where y is the dependent variable, x is the independent variable, and f(x,y) is a function that relates the two variables.
How do you solve a first-order differential equation?
There are various methods for solving first-order differential equations, such as separation of variables, integrating factor, and substitution. The specific method used depends on the form of the equation and the initial conditions.
What is the importance of first-order differential equations in science?
First-order differential equations are widely used in science to model and understand various phenomena in fields such as physics, chemistry, biology, and economics. They are essential for predicting the behavior of systems and making accurate predictions.
Can first-order differential equations have more than one solution?
Yes, first-order differential equations can have infinitely many solutions. This is because there are often multiple functions that satisfy the equation and initial conditions. However, some first-order differential equations may have unique solutions.
