Solution: Is $u$ a Constant Function on $S$?
  • MHB
  • Thread starter Chris L T521
In summary, a constant function is a mathematical function that always gives the same output regardless of the input. It can be determined by examining its graph or equation, and its solution is simply the constant value itself. A constant function is different from other types of functions because it does not change based on the input. It can be defined on any set, with the same output for every input.
Chris L T521
MHB
915
Thanks to those who participated in last week's POTW! Here's this week's problem!
Problem: Let $S$ be a solid region in $\mathbb{R}^3$ with outward unit normal $\mathbf{n}$, and let $u$ be a function that satisfies Laplace's equation ($\nabla^2 u = 0$) and the boundary condition $\nabla u(x,y,z)\cdot\mathbf{n} = 0$ for $(x,y,z)\in\partial S$. Show that $u$ is a constant function.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Delays this week brought to you by filling out paperwork for a new job and other annoying important things. >_>
No one answered this week's problem. You can find the solution below.
[sp]We will need to use Green's identity to answer this problem. Recall that if $f$ and $g$ are continuously differentiable scalar-valued functions on an open set $U$ in $\mathbb{R}^3$, then for any solid region $S$ contained in $U$,
\[\iiint\limits_S \nabla f\cdot\nabla g \,dV = \iint\limits_{\partial S} f\nabla g\cdot \mathbf{n}\,d\sigma -\iiint\limits_S f\nabla^2 g\,dV.\]
In our case, we take $f=g=u$ to see that
\[\iint\limits_S \nabla u \cdot \nabla u \,dV = \iint\limits_{\partial S} u\nabla u \cdot \mathbf{n}\,d\sigma - \iint\limits_S u\nabla^2 u \,dV.\]
Since $\nabla u\cdot\mathbf{n} = 0$ on $\partial S$, the first integral is zero. Likewise, since $u$ satisfies Laplace's equation $\nabla^2 u = 0$, it follows that the second integral is zero. Therefore, we now see that
\[\iiint\limits_S \nabla u \cdot \nabla u \,dV = \iiint\limits_S \|\nabla u\|^2\,dV = 0.\]
Since the integrand is continuous and non-negative, it must follow that $\nabla u =0$ which implies that $u$ is constant on $S$.$\hspace{.25in}\blacksquare$ [/sp]
FAQ: Solution: Is $u$ a Constant Function on $S$?
What is a constant function?
A constant function is a mathematical function that always gives the same output regardless of the input. In other words, the output is constant or unchanging.
How do you determine if a function is constant?
To determine if a function is constant, you can examine its graph or its equation. If the graph is a horizontal line, or if the equation only contains a constant value, then the function is constant.
What is the solution to a constant function?
The solution to a constant function is simply the constant value itself. This is because the output of the function will always be the same regardless of the input.
How is a constant function different from other types of functions?
A constant function is different from other types of functions because it does not change based on the input. Other functions, such as linear or quadratic functions, have a variable input that affects the output.
Can a constant function be defined on any set?
Yes, a constant function can be defined on any set. The function will simply have the same output for every input in the set, making it constant.
