Solution needed 4 a very good problem
  • Thread starter rahul963
In summary, The conversation discusses solving for x and y in the equation x^3 - y^2 = 2006 in integers. The person being asked what they have tried so far and what sort of mathematics they know to solve the problem. They mention using substitution and guess and check, but are unsure of the correct method. The other person suggests that the problem may be a math olympiad problem.
rahul963
Solve x^3 - y^2 = 2006 in integers.
What have you tried so far? What sort of mathematics have you learned to solve this problem?
number theory problem? do u knowsolution r not?
zurtex? do u hve ny idea?
Well yes I do know a solution and I would have a guess it's the only solution, but I only know this solution by running the problem through mathematica, I was wondering what sort of number theory you know so I might be able to help you rather than just give you an answer.
[tex]x^3 - y^2 = 2006[/tex]
[tex]y^2 = x^3 - 2006[/tex]
[tex]y = \sqrt{x^3 - 2006}[/tex]
So then, using substitution...
[tex]x^3 - \sqrt{x^3 - 2006} = 2006[/tex]
I'm sure this isn't nearly sophisticated enough, and I've probably gotten into a rut of some sort (I know I don't know how to continue ><)... It's what I tried, though-- and now I'm curious as to how you would continue, or if I'm completely wrong... If this is digressing from the topic, I apologize-- just ignore me if that is the case...
You can't do that. You have a single equation with two variables which you substituted back into your equation. It will give you something in along the lines of 0 = 0 or x = x. And it does:
[tex]x^3 - x^3 + 2006 = 2006[/tex]
I don't know the theory behind it, but it only took a few minutes of guess and check to solve.
Is this a math olympiad problem by any chance?
FAQ: Solution needed 4 a very good problem
What is a solution?
A solution is a way to solve a problem or address a specific need. It can involve a combination of ideas, resources, and actions to achieve a desired outcome.
How do I identify a good problem?
A good problem is one that is important, relevant, and has potential for improvement. It should also be specific and clearly defined, making it easier to find a solution.
What makes a solution effective?
An effective solution not only addresses the problem, but also considers potential obstacles and provides a sustainable and feasible approach. It should also be measurable and adaptable to changing circumstances.
How do I come up with a solution?
There are various methods for generating solutions, such as brainstorming, research, and experimentation. It is also helpful to involve others and gather diverse perspectives to come up with a well-rounded solution.
What steps should I take to implement a solution?
The steps for implementing a solution may vary, but some common ones include planning, testing, and refining the solution. It is also important to communicate and collaborate with others who will be involved in the implementation process.
