I Solution of delayed forcing function
  • I
  • Thread starter Thread starter Jag1972
    Function
Jag1972
TL;DR Summary
Compare the solution of delayed forcing function differential equation using Laplace transform and method of undermined coefficients.
Tried to figure out myself but have now admitted defeat, requesting some guidance from you good people. Not looking for any specific answers, unless the problem is my working out and not my process.
If we take the following differential equation: ##y(t)'' + 4y(t) = 7u(t-2)## and determine solution for following time range: ##\:\:0\leq t \lt \infty \: ## with initial conditions: ##y(0) = 2, \:y'(0) = 4##.
First solved using Laplace Transforms (This is the most straight forward way), this is solution calculated.
##y(t) = u(t-2)(\frac {7}{4} - \frac {7}{4} cos (2(t-2))) + 2 cos (2t) + 2 sin (2t)##
I tried to get a solution that would match this using method of undermined coefficients. This was my approach which felt intuitive to me. Determined 2 separate solutions for the following differential equations:1) ##y(t)'' + 4y(t) = 0\:\:## for range ##\:\:0\leq t \lt 2 \: ## initial conditions ##y(0) = 2, \:y'(0) = 4##.
2) ##y(t)'' + 4y(t) = 7## for range ##\:\:0\leq t \lt \infty \: ## initial conditions ##y(2) = -2.8, \:y'(2) = 0.4##.
The 2 solutions obtained were:
1) ##y(t)=2 cos(2t) + 2 sin (2t)\:\:## for range ##\:\:0\leq t \lt 2 \: ##
The initial conditions for the second solution were determine using solution 1 and its derivative. Simply replaced t with 2 in both equations.
2) ##y(t)=(2.9) cos(2t) + (3.5) sin (2t) + \frac {7}{4}\:\:## for range ##\:\:0\leq t \lt 2 \: ##
My problem is that the Laplace transform and Undermined coefficients solutions don't give same results for ##t\geq2##.
for example when ##t=3##
1) Laplace Transform
## = u(1)(\frac {7}{4} - \frac {7}{4} cos (2(1))) + 2 cos (5) + 2 sin (5)##
2) Undermined Coefficients
##-0.7836=(2.9) cos(5) + (3.5) sin (5) + \frac {7}{4}\:\:## for range ##\:\:0\leq t \lt 2 \: ##
Would appreciate any support on this.
Jag1972 said:
TL;DR Summary: Compare the solution of delayed forcing function differential equation using Laplace transform and method of undermined coefficients.
It is a mistake to use decimal approximations for the coefficients here. Instead retain the exact expressions in terms of \cos 4 and \sin 4. For <br /> y(t) = \frac74 + C\cos 2t + D\sin 2t I find \begin{split}<br /> C = 2 - \frac74 \cos 4 \\<br /> D = 2 - \frac74 \sin 4. \end{split} You can then simplify the result using the angle sum and difference formulae, <br /> \begin{split}<br /> \cos(a \pm b) &amp;= \cos a \cos b \mp \sin a \sin b, \\<br /> \sin(a \pm b) &amp;= \sin a \cos b \pm \cos a \sin b.\end{split} You should find that you get the same solution as the Laplace method.
Many thanks sir for your reply, I am working it out now. Why is it a mistake to work out the values for the coefficients
Keeping them as exact values means that you can apply the trigonometric identities I gave to convert your expression into that obtained by the Laplace transform method, thus showing that they are indeed equal.
I am a little embarrassed to ask for help again but am stuck on the mathematics part and request further guidance.
How are you getting the value for constants, C and D. Are both solutions evaluated when t = 2, as shown?
## y(t) = 2 cos (4) + 2 sin (4)## for ## \:\:0\leq t \lt2##
## y(t) = \frac {7}{4}+C cos (4) +D sin (4)## for ## \:\:2\leq t \lt \infty##
when t=2, they equal each other
## y(t) = 2 cos (4) + 2 sin (4) = \frac {7}{4}+C cos (4) +D sin (4)##
Is this how the constants were worked out?
Thank you so much in advance
Got the answer, however the expression for my constants is slightly different to yours, not sure why.
picking up for solution of differential equation using method of undetermined coefficients for following time range: ## 2\leq t \lt \infty##
Wrote equation and its derivative
## y =\:\:\:\:\:\:A cos(2t) + B sin(2t) + \frac{7}{4}\:\:\:\:\:\:## Equation 1
## y' = -2A sin(2t) + 2B cos(2t) \:\:\:\:\:\:\:\:\:\:\:\:## Equation 2
Multiplied Equation 1 by ## 2 sin (2t)## and equation 2 by ## cos(2t)## and added both
## \:\:\:\:2A cos(2t) sin(2t) + 2B sin^2(2t) + \frac{7}{2} sin(2t)##
## -2A sin(2t) cos(2t) + 2B cos^2(2t) ##
## 2B + \frac{7}{2} sin(2t) ## therefore ## B= -\frac{7}{4} sin (2t)##
By substituting B into Equation 2, got ##A = -\frac{7}{4} cos(2t)##
Set t = 2, this where the differential equation has non-zero input
A = -\frac{7}{4} cos(4)##
B = -\frac{7}{4} sin(4)##
The expressions obtained for unknown constants were slightly different to yours:
C = ##2 -\frac{7}{4} cos(4)##
D = ##2 -\frac{7}{4} sin(4)##
After substituting the expressions obtained for A and B into original differential equation and using trig identities got the same expression as Laplace Transform.
## y =\:\:\:\:\:\:(- \frac{7}{4} cos(4)) cos(2t) + (- \frac{7}{4} sin(4)) sin(2t) + \frac{7}{4}\:\:\:\:\:\:##
## y =\:\:\:\:\:\:- \frac{7}{4} cos(4) cos(2t) - \frac{7}{4} sin(4) sin(2t) + \frac{7}{4}\:\:\:\:\:\:##
Used product identities
## y =\:\:\:\:\:\:- \frac{7}{4} (cos(4) cos(2t) + sin(4) sin(2t) )+ \frac{7}{4}\:\:\:\:\:\:##
## y =\:\:\:\:\:\:- \frac{7}{4} (\frac{cos(2t-4)+cos(2t+4)}{2}) + (\frac{cos(2t-4)-cos(2t+4)}{2}) + \frac{7}{4}\:\:\:\:\:\:##
## y =\:\:\:\:\:\:- \frac{7}{4} (\frac{cos(2t-4)+cos(2t+4)+ cos(2t-4)-cos(2t+4)}{2}) + \frac{7}{4}\:\:\:\:\:\:##
## y =\:\:\:\:\:\:- \frac{7}{4} cos(2t-4) + \frac{7}{4}\:\:\:\:\:\:#### y =\:\:\:\:\:\: \frac{7}{4} - \frac{7}{4} cos(2(t-2)) \:\:\:\:\:\:##
This now matches my answer from Laplace transforms. The solution here only shows the function when ##t\leq2##
My question in practical terms, in order to plot function would we need to show the homogeneous solution when ##2\leq t \lt \infty## . The Laplace transform solution shows both parts summed. Does the homogeneous part actually play any part in the function when ##t\geq 2##
Should it be
##y(t) = u(t-2)(\frac {7}{4} - \frac {7}{4} cos (2(t-2))) + (u(t) - u(t - 2))(2 cos (2t) + 2 sin (2t))##
The u(t-2) on the right should now be exactly 2 should be just less than 2. Hope I have explained my question properly.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
