Solution of system with matrix
In summary, the problem asks to find values of ##\alpha## for which the system ##AX + \alpha X = (1, 1, 1, 1)^t## has solutions. This can be solved by finding the determinant of ##(A + \alpha I_4)## and setting it equal to zero. The resulting 4th degree polynomial will have some values of ##\alpha## which will result in no solutions, and all other values will have a unique solution for x, y, z, and t expressed in terms of ##\alpha##. Therefore, the solution to the problem is all values of ##\alpha## except for those that are roots of the 4th degree polynomial
Kernul
211
Find out for which values of ##\alpha## the system ##AX + \alpha X = (1, 1, 1, 1)^t## has solutions.
$$A = \begin{pmatrix}
6 & 0 & -1 & 2 \\
3 & 5 & -3 & 6 \\
-2 & 0 & 7 & -4 \\
2 & 0 & 1 & 0
\end{pmatrix}
X = \begin{pmatrix}
x \\
y \\
z \\
t
\end{pmatrix}$$
At first I wanted to proceed with a system, since it's what the problem asks. So I wrote ##AX + \alpha X = (1, 1, 1, 1)^1## like this:
##\begin{cases}
6x - z + 2t + \alpha x = 1 \\
3x + 5y - 3z + 6t + \alpha y= 1 \\
-2x + 7z - 4t + \alpha z= 1\\
2x + z + \alpha t = 1
\end{cases}##
And then I should proceed, right?
But the professor showed me that you can do this with matrices this way too:
##AX + \alpha X = (A + \alpha I_4)X##
And that if the determinant of ##(A + \alpha I_4) \neq 0 \implies \exists! \alpha##, while if it's equal to 0 the solution depends from ##rank(A + \alpha I_4)## and ##rank(A + \alpha I_4 | B)##, which I don't understand what the professor meant with ##B##. Would it be the ##(1, 1, 1, 1)^t##? In this case, if the two ranks are equal, does it mean it still has more than just one solution? And if they are not equal, does it mean no solution at all?
Anyway, I start by finding the determinant of ##(A + \alpha I_4)## but I find myself with a ##4^{th}## grade equation like this: ##\alpha^4 + 18 \alpha^3 + 105 \alpha^2 + 208 \alpha + 40##
I'd like to know if someone finds out a different determinant, because it could be that I messed up while calculating it.
6 & 0 & -1 & 2 \\
3 & 5 & -3 & 6 \\
-2 & 0 & 7 & -4 \\
2 & 0 & 1 & 0
\end{pmatrix}
X = \begin{pmatrix}
x \\
y \\
z \\
t
\end{pmatrix}$$
##\begin{cases}
\end{cases}##
I used the computer package Maple to do all the computations, and did get a different polynomial from yours. Mine is ##\alpha^4 + 18 \alpha^3 + 105 \alpha^2 + c_1 \alpha + c_0## for some ##c_1, c_0## different from yours.
Anyway, what is happening is that for a small number of numerical values of ##\alpha## your equations have no solution; for all other values of ##\alpha## your equations will have a unique solution; see below.
You can take the 4 x 4 system of equations you have written above, and use standard elementary elimination methods to solve for x, y, z, t in terms of ##\alpha##. For example, you can use the first equation to solve for z in terms of x and t; then you can put that expression into the other three equations, leaving you with a 3 x 3 system of linear equations in the variables y, z and t. Now you can (for example) use the first equation of this new 3 x 3 system to solve for y in terms of z and t; then you can substitute that expression for y into the other two equations, to get a new 2 x 2 linear system in terms of the variables z and t alone. Then you can solve for z in terms of t, and finally get an equation for t alone. Everything will contain the parameter ##\alpha##, and the solution will be valid if you do not divide by zero at the end. That will give you a condition of ##\alpha##; it will be a 4th degree polynomial which, when equal to zero, makes your solution invalid. In other words, as long as ##\alpha## is not a root of a certain 4th degree polynomial, you will not be dividing by zero and so will get a valid (unique) solution for x, y z and t (all expressed in terms of ##\alpha##).
But isn't finding the root of the 4th degree polynomial what the exercise asks me? I need to know for what values of ##\alpha## the system has solutions.
From what you're saying, it means that ##\alpha## can be anything as long as it is not a root of the 4th degree polynomial in order for the system to have solutions, right?
Yes, that is what I said.
Likes Kernul
You ought to rearrange that matrix to make the determinant easier. And, avoid generating a 4th degree polynomial. Hint: the second column has three ##0##'s and the other entry would be ##5+\alpha##, so that gives you one of the factors for a start.
I divide that row by ##5 + \alpha## then? So I have ##1## and end up with a 3rd degree polynomial:
##\alpha^3 + 13\alpha^2 + 40\alpha##
which becomes:
##\alpha(\alpha^2 + 13\alpha + 40)##
and it is equal to ##0## if ##\alpha = 0## or (the solutions of the 2nd degree equation) ##\alpha = -5, \alpha = -8##.
Knowing now for what ##\alpha## the determinant becomes ##0##, do I have to see the three cases (with the three ##\alpha## found) in which the ranks of ##A + \alpha I_4## and ##A + \alpha I_4 | B## tell me the solutions? This is what my professor told me in case the determinant would have been equal to ##0##. If I remember right, if the two ranks are the same, then there are solutions, if they are different, then there is no solution. Am I right?
which becomes:
Dividing by ##5+ \alpha## was not right. What about ##\alpha = -5##? You should have kept that as a ready-made factor in your polynomial.
You were lucky that ##\alpha + 5## was also a factor of what was left!
Determinant not equal to 0 gives you a unique solution to your equation. For the values of ##\alpha## that make the determinant 0 you have more work to do to decide whether there are solutions.
For solutions, yes, the two matrices must have the same rank.
But I couldn't simply give ##\alpha## a value of my choice since, after all, I am trying to find them through the determinant itself.
What is the work that I should do? I know I should then delete a row from the system, but then I would have three equations with five unknown?
Anytime you divide by something like ##5+ \alpha## you must consider the case when ##5 + \alpha = 0##. In this case, you could have noticed that ##\alpha = -5## made the determinant ##0## and put that to one side, or you could have continued and got ##5 + \alpha## as a factor of your polynomial.
It does look like there is still a bit of work to do to check solutions for ##\alpha = 0, -5, -8##.
For most values of ##\alpha## you do not need to do any more work because you know that the system ##(A + \alpha I)X = e## has a unique solution. The question did not ask you to find that solution, but one way of doing the problem would have been to actually find it. However, finding roots of the determinant is faster and easier.
That leaves three values ##\alpha = 0, -5, -8##. For each of those values a solution is not guaranteed to exist, but it might! That is, there could be a solution even though the determinant equals 0. The easiest way to proceed would be to try to solve the linear system in each case.
Oh, that's true, because ##5 + \alpha## was the only one in the column, and putting it equal to ##0## means that the column would be all zeros and automatically get a determinant equal to ##0##.
That leaves three values ##\alpha = 0, -5, -8##. For each of those values a solution is not guaranteed to exist, but it might! That is, there could be a solution even though the determinant equals ##0##. The easiest way to proceed would be to try to solve the linear system in each case.
Yeah, that's what I thought too about the three values of ##\alpha##. What I'm asking is if I should take the entire system or delete one of the equations since the determinant in those three ##\alpha## is ##0##.
Kernul said:
Oh, that's true, because ##5 + \alpha## was the only one in the column, and putting it equal to ##0## means that the column would be all zeros and automatically get a determinant equal to ##0##.Yeah, that's what I thought too about the three values of ##\alpha##. What I'm asking is if I should take the entire system or delete one of the equations since the determinant in those three ##\alpha## is ##0##.
If I could see a quick way to finish off this problem, I would give you a hint. But, I must admit, I don't see any shortcuts.
Likes Kernul
Related to Solution of system with matrix
1. What is a solution of a system with matrix?
A solution of a system with matrix is a set of values for the variables in the system that satisfy all of the equations in the system. In other words, it is the values that make all of the equations true when substituted into the system.
2. How is a system with matrix solved?
A system with matrix is typically solved using techniques such as Gaussian elimination, Cramer's rule, or matrix inversion. These methods involve manipulating the matrix equations to reduce them to a simpler form and then solving for the variables.
3. What is the difference between a consistent and an inconsistent system with matrix?
A consistent system with matrix has at least one solution, while an inconsistent system with matrix has no solutions. In other words, a consistent system has a set of values that satisfy all of the equations, while an inconsistent system does not have a solution that satisfies all of the equations.
4. Can a system with matrix have more than one solution?
Yes, a system with matrix can have more than one solution. This is known as an infinite solution, where there are multiple sets of values that satisfy all of the equations in the system. This can occur when there are redundant equations in the system.
5. What is the role of matrices in solving systems of equations?
Matrices provide a convenient and efficient way to represent systems of equations. By using matrix operations, such as row operations, it is possible to manipulate the system and solve for the variables. Matrices also allow for the use of computer algorithms to solve large systems of equations quickly and accurately.
