Solution of the Kolmogorov forward equation for a linear process
In summary, we discussed the 1-D linear system governed by the equation "dx/dt = a*x(t) + n(t)", and how it can be represented using Ito's stochastic differential equation and the Kolmogorov forward equation. We also explored the assumption that the system state's probability density function is Gaussian and how this relates to the effectiveness of the Kalman filter. However, the proposed solution of a Gaussian distribution with drift and diffusion does not satisfy the KFE and is not a valid solution.
dalves
Consider the 1-D linear system governed by:
where "a" is a scalar and:
x(t) = system state
n(t) ~ N(0, sigma^2)
We can write Ito's stochastic differential equation of the previous process as:
"dx = a*x*dt + 1/2*sigma^2*dW_t"
where:
x = system state
a*x = drift term
1/2*sigma(t,x)^2 = diffusion term
W_t = Wiener process
The time evolution of the system state's probability density function " pdf(x(t)) = p(x,t) " is governed by the Kolmogorov forward equation (aka Fokker-Planck equation):
"dp(x,t)/dt = -d/dx[a*x*p(x,t)] + 1/2*sigma^2*d^2p(x,t)/dx^2"
which after expanding gives:
"dp(x,t)/dt = -a*p(x,t) - a*x*dp(x,t)/dt + 1/2*sigma^2*d^2p(x,t)/dx^2"
where "d/dt", "d/dx" and "d^2/dx^2" are partial derivatives.
Because the process is linear and "n(t) ~ N(0, sigma^2)", if we further assume that "x(t=0) ~ N(x0, sigma_x^2)", then "pdf(x) = p(x,t)" is Gaussian for t >= 0. Which is basically why the Kalman filter works.
Furthermore, in the case of "a = 0", i.e. pure diffusion, the solution of the KFE is:
"p(x,t) = ((2*pi*sigma*t)^(-1/2))*exp(-((x-x0)^2)/(2*sigma*t))"
which is indeed a Gaussian distribution thus supporting the previous statement.
I therefore expected that a solution of the type (gaussian drift + diffusion):
"p(x,t) = ((2*pi*sigma*t)^(-1/2))*exp(-((x-beta*t-x0)^2)/(2*sigma*t))"
would solve the KFE. However, it is easy to verify that this is not a solution of the KFE above.
Undoubtedly my reasoning is wrong and, most likely, in more than one place. Where?
Your reasoning is incorrect when you assumed the solution of the KFE would be a Gaussian distribution with drift (beta*t). This solution does not satisfy the KFE since the drift term in the KFE has an x-dependence that is not present in the solution. Therefore, the solution you proposed does not satisfy the KFE and is not a valid solution.
Related to Solution of the Kolmogorov forward equation for a linear process
1. What is the Kolmogorov forward equation?
The Kolmogorov forward equation, also known as the Fokker-Planck equation, is a partial differential equation that describes the probability density function of a stochastic process. It is used to analyze the evolution of a system over time, where the system is subject to random fluctuations.
2. How is the Kolmogorov forward equation solved for a linear process?
The solution of the Kolmogorov forward equation for a linear process involves finding the transition probability density function, which describes the probability of the system transitioning from one state to another. This can be done using various methods such as the method of characteristics or the separation of variables technique.
3. What is the importance of the Kolmogorov forward equation in scientific research?
The Kolmogorov forward equation has many important applications in various fields of science, such as physics, chemistry, biology, and finance. It allows for the analysis of complex systems with random fluctuations, making it a valuable tool for understanding real-world phenomena.
4. Can the Kolmogorov forward equation be applied to non-linear processes?
Yes, the Kolmogorov forward equation can be extended to non-linear processes, but the solution becomes more complex and may require numerical methods. In some cases, simplifications or approximations may need to be made to solve for the transition probability density function.
5. What are some limitations of the Kolmogorov forward equation?
One of the main limitations of the Kolmogorov forward equation is that it assumes the system is in a steady state, meaning the probability density function does not change over time. It also assumes that the system is Markovian, meaning the future state of the system only depends on the present state and not on past states. These assumptions may not hold true in all real-world systems, limiting the applicability of the equation.
