Solution of the One-Speed Transport Eqn. by K M Case method
In summary, the ansatz solution of the one-speed transport equation involves separating the variables and solving two ODEs, one for X(x) and one for T(t). The eigenvalues +vo and -vo were chosen because they satisfy the form of the ansatz solution and can be used to solve the PDE. The integral in equation 2.14 is an indefinite integral that can be evaluated using standard techniques. The two discrete eigenvalues +vo and -vo satisfy equation 2.16 because they are solutions of the two ODEs derived from the one-speed transport equation.
Sharfu
In the book, Nuclear Reactor Theory, Glasstone, Bell, under section 2.2
SOLUTION OF THE ONE-SPEED TRANSPORT EQUATION BY THE SEPARATION OF VARIABLES, I have difficulty in understanding the derivation. Hope some one can explain the derivation or give a reference where the derivation has been derived with explanation for the different (read each and every) steps. (The book is also available as TID 25606). The problem definition is equation 2.12. Then solved according to separation of variable methods for PDE.
The ansatz solution thing is a new one (for someone with an engineering course in DE only) but mathematically viable. But why Mr. Case sought solutions with eigenvalues of Ψ? what is mathematical reason for it? As I am thinking the solution for "Source-Free Infinite Medium" as a sloped line going to zero as x increase toward infinity.
RHS of equation 2.14 contain an integral. Can someone show some link or reference where such PDE have been solved.
How integral of equation 2.19 is determined! What is the mathematical name for such calculation or some reference or link?
How can I see two discrete eigenvalues +vo and -vo satisfy equation 2.16?
Spoiler: I admit I am a very slow learner, so do not get annoyed if I could not understand some very basic concepts. Secondly it would look too "demoralizing" if I skip a topic within first hundred pages of the book!
The ansatz solution of the one-speed transport equation involves making an assumption of the form Ψ(x,t)=X(x)T(t). This is a mathematical technique that is often used to solve partial differential equations (PDEs). The idea is to assume that the solution can be written as the product of two functions, one of which depends only on x and the other only on t. By doing this, it is possible to separate the variables in the PDE and reduce the problem to two ordinary differential equations (ODEs), one for X(x) and one for T(t). This can then be solved by standard ODE techniques.Mr. Case sought solutions with eigenvalues of Ψ because the ansatz he was using assumed that the solution could be written as a product of two functions - one depending on x and the other on t. He wanted to find solutions which would satisfy this form. To do this, he separated the variables in the PDE and reduced the problem to two ODEs, one for X(x) and one for T(t). He then looked for solutions which would have the form Ψ(x,t)=X(x)T(t), where X(x) and T(t) are the solutions of the two ODEs. These solutions are called eigenvalues of Ψ.The integral in equation 2.14 is an integral of the form ∫φ(x)dx, where φ(x) is a function of x. This type of integral is called an indefinite integral. It is used to calculate the area under a curve and can be evaluated using standard integration techniques.The two discrete eigenvalues +vo and -vo satisfy equation 2.16 because they are solutions of the two ODEs that Mr. Case derived from the one-speed transport equation. The ODEs are X'(x)=voX(x) and T'(t)=voT(t). The solutions of these two ODEs are X(x)=Ae^(+vo*x) and T(t)=Be^(+vo*t) for +vo, and X(x)=Ce^(-vo*x) and T(t)=De^(-vo*t) for -vo. Substituting these solutions into equation 2.12 gives equation 2.16.
Related to Solution of the One-Speed Transport Eqn. by K M Case method
1. What is the "One-Speed Transport Equation"?
The One-Speed Transport Equation is a mathematical model used to describe the behavior of neutrons in a nuclear reactor. It takes into account the rate of change of neutron density, the direction and speed of neutron movement, and the absorption and scattering of neutrons by reactor materials.
2. Who is K M Case and what is the Case method?
K M Case is a renowned nuclear physicist who developed the Case method for solving the One-Speed Transport Equation. The Case method involves breaking down the equation into smaller, more manageable parts and solving them sequentially to find the overall solution.
3. What is the significance of solving the One-Speed Transport Equation?
Solving the One-Speed Transport Equation is crucial in understanding the behavior of neutrons and the overall performance of a nuclear reactor. It allows scientists and engineers to predict and control the reaction rate, power output, and safety of the reactor.
4. What are the limitations of the Case method for solving the One-Speed Transport Equation?
The Case method assumes certain simplifications and assumptions, such as a uniform distribution of neutrons and a constant speed of neutron movement. These assumptions may not always hold true in real-world scenarios, leading to some inaccuracies in the results.
5. Are there other methods for solving the One-Speed Transport Equation?
Yes, there are other methods such as the Finite Difference Method and the Monte Carlo Method. Each method has its own advantages and limitations, and the choice of method depends on the specific problem and the desired level of accuracy.
