MHB Solution of the recurrence relation
The discussion focuses on solving the recurrence relation defined by f_n = (2/a^2 + b)f_{n-1} - (1/a^4)f_{n-2} with initial conditions f_0 = 1 and f_{-1} = 0. The user initially calculates several values for f_n but struggles to identify a clear pattern. A suggestion is made to utilize the characteristic equation method, leading to the formulation m^2 - cm - d = 0. The user expresses gratitude for the hint and confirms they have made progress in solving the recurrence relation. The conversation highlights the importance of characteristic equations in solving such mathematical problems.
mathmari
MHB
Hey! :o
How can we solve the following recurrence relation?
$$f_n=\left (\frac{2}{a^2}+b\right )f_{n-1}-\frac{1}{a^4}f_{n-2} \\ f_0=1, f_{-1}=0$$
I calculated some values to see if there is a general pattern, but it doesn't seems so...
$$f_1=\left (\frac{2}{a^2}+b\right ) \\ f_2 =\left (\frac{2}{a^2}+b\right )^2-\frac{1}{a^4} \\ f_3 =\left (\frac{2}{a^2}+b\right )^3-\frac{2}{a^4}\left (\frac{2}{a^2}+b\right ) \\ f_4=\left (\frac{2}{a^2}+b\right )^4-\frac{3}{a^4}\left (\frac{2}{a^2}+b\right ) ^2+\frac{1}{a^8} \\ f_5=\left (\frac{2}{a^2}+b\right )^5-\frac{4}{a^4}\left (\frac{2}{a^2}+b\right ) ^3+\frac{3}{a^8}\left (\frac{2}{a^2}+b\right )$$
Have calculated these values right?
Is there an other way to find the solution of the recurrence relation? (Wondering)
mathmari said:
Hey! :o
Start with:
[math]f_n = c f_{n-1} + d f_{n-2}[/math]
[math]f_{n + 2} - c f_{n + 1} - d f_n = 0[/math]
The characteristic equation is [math]m^2 - cm - d = 0[/math]
Can you take it from here?
-Dan
I did it! Thanks for the hint! (flower)
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
