Solution strange, differential equation
In summary, the conversation discusses how to solve the differential equation m(d2x/dt2) + ksin(x) = 0. The method of "quadrature" is suggested, where v = dx/dt and d2x/dt2 = v(dv/dx). By integrating both sides, the equation can be reduced to v = sqrt((2k/m)cos(x) + C') and an initial condition is needed for solving for x(t).
Phizyk
25
Hi!
I have big problem with solve this equation:
[tex]m\frac{d^{2}x}{dt^{2}}+ksinx=0[/tex]
I can't go ahead, because I don't know how solve this
[tex]\frac{dx}{\sqrt{cosx}}=\sqrt{\frac{2k}{m}}dt[/tex]
Phizyk
Since the independent variable, t, does not appear explicitely in the equation, that is a candidate for "quadrature".
Let v= dx/dt. Then d2x/dt2= dv/dt. But by the chain rule, dv/dt= (dv/dx)(dx/dt). And dx/dt= dv/dt, of course. That is d2x/dt2= (dx/dt)(dv/dt)= vdv/dx.
Your differential equation can be reduced to vdv/dx= -ksin(x) which is "separable":
mvdv= - k sin(x)dx. Integrating both sides, (m/2)v2= k cos(x)+ C. (That square is the reason for the name "quadrature".) Then v2= (2k/m) cos(x)+ C' or
v= dx/dt= sqrt((2k/m) cos(x)+ C').
I assume that, in order to get rid of that constant of integration, C', you must have some initial condition on dx/dt.
Great. Thanks Hallsoflvy.
But this equation [tex]\frac{dx}{dt}=\sqrt{\frac{2k}{m}cosx+C^{'}}[/tex] can I solve? Can I obtain x(t)? For t=0 x=0. It's a equation of motion.
FAQ: Solution strange, differential equation
What is a solution to a strange differential equation?
A solution to a strange differential equation is a function that satisfies the equation and its initial conditions. It describes the relationship between the variables in the equation and can be used to predict the behavior of the system.
How is a strange differential equation different from a regular differential equation?
A strange differential equation is a type of differential equation that involves non-linear dynamics and can exhibit chaotic behavior. It is different from a regular differential equation which usually has a predictable, stable solution.
What are some real-world applications of strange differential equations?
Strange differential equations have been used to model a wide range of phenomena, including weather patterns, population dynamics, and the behavior of electrical circuits. They are also used in fields such as economics, biology, and physics to study complex systems.
How do scientists solve strange differential equations?
Solving strange differential equations can be challenging and often requires numerical methods or computer simulations. Scientists may also use analytical techniques, such as phase space analysis or Lyapunov exponents, to gain insight into the behavior of the system.
Can strange differential equations accurately predict the behavior of a system?
While strange differential equations can provide valuable insights into the behavior of complex systems, their predictions may not always be accurate. This is due to the sensitivity of chaotic systems to initial conditions and the limitations of mathematical models. However, they can still be useful in understanding the overall behavior and trends of a system.
