Solution to complicated systems of three variables using matrices
In summary, the question asks to solve each of the following system of equations, using row reduction method:First system: $(\log4)x+(3+2\log4)y+(6+3\log4)z=4+9\log4$Second system:x+(1+pi)y+(1+2pi)z=1+3pi(1/4)x+(1/2)y+(3/4)z=1
Hyunqul
Hello,i have been trying to self-study matrices topics, during that I came across two complicated problems, and I wish I could provided with help to solve them : The question asks to solve each of the following system of equations, using row reduction method (Again...I assure that my teacher has not taught us matrices yet...It's a self attempt) :
First system :
View attachment 58Second system :
Thanks.
First system :
https://www.physicsforums.com/attachments/58Second system :
https://www.physicsforums.com/attachments/59
Thanks.
For the first system, I assume the first equation should be
$(\log4)x+(3+2\log4)y+(6+3\log4)z=4+9\log4 $
For the second system, divide the second equation by e2. Multiply the last equation by 4.
Both systems have weird coefficients, but are otherwise fairly standard.
The matrix form for the firsrt would be
$\begin{bmatrix}log 4 & 3+ 2log 4 & 6+ 3log 4 \\ 1+ log 3 & 5+ 3log 3 & 3+ 5log 3 \\ -1 & 0 & 1 \end{bmatrix}\begin{bmatrix}x \\ y \\ z \end{bmatrix}= \begin{bmatrix}9+ 4log 4 \\ 4+ 7log 3 \\ 2\end{bmatrix}$
For the second
$\begin{bmatrix}1 & 1+ \pi & 1+ 2\pi \\ 4e^2 & 3e^3 & 2e^2 \\ \frac{1}{4} & \frac{1}{2} & \frac{3}{4}\end{bmatrix}\begin{bmatrix}x \\ y \\ z\end{bmatrix}= \begin{bmatrix}1+ 3\pi \\ e^2 \\ 1\end{bmatrix}$
Now use whatever matrix methods you know, Gauss elimination, inverting, LU decomposition. The numbers are peculiarly written, but they are just numbers.
(Not matrix related but an obvious first step is to divide through the second equation in the second set by $e^2$.)
Here's an idea. Re-write your equations as
$\log 4\left(x + 2y + 3z-4\right) + 3(y+2z-3) = 0$
$\left(x+2y+3z-4\right) + \ln 3 \left(x+3y+5z-7\right) = 0$
$x - z + 2 = 0$
If you let
$u =x + 2y + 3z-4$, $v = y+2z-3$ and $w =x+3y+5z-7$
then your system becomes
$\begin{align}
\log 4 u + 3v &= 0,\\
u + \ln 3 w &= 0,\\
u - 2v &= 0,
\end{align}$
whose solution is
$u=0$, $v = 0$ and $w=0$.
Thus, you are required to solve
$\begin{align}
x + 2y + 3z&=4,\\
y+2z&=3,\\
x+3y+5z&=7.
\end{align}$
Hello,
It is great that you are self-studying matrices and attempting to solve these complicated systems of equations. Using matrices is a powerful tool in solving systems of equations, and the row reduction method is one approach that can be used.
For the first system, we can write the equations in matrix form as:
[1 2 -3 | -2]
[2 -1 1 | 6]
[3 1 -1 | 5]
To solve this system using the row reduction method, we can use elementary row operations to transform the matrix into an upper triangular form. This can be done by multiplying a row by a scalar, adding a multiple of one row to another, or swapping rows. The goal is to get zeros below the diagonal elements.
After performing these operations, we get the following matrix:
[1 2 -3 | -2]
[0 -5 7 | 10]
[0 0 0 | -1]
From this, we can see that the third equation is inconsistent, meaning there is no solution for the system. The first two equations can be rewritten as:
x + 2y - 3z = -2
-5y + 7z = 10
Using back substitution, we can solve for y and z in terms of x. However, since the third equation has no solution, the system has no unique solution.
For the second system, we can write the equations in matrix form as:
[1 1+pi 1+2pi | 1+3pi]
[1/4 1/2 3/4 | 1]
Using the row reduction method, we can perform the same elementary row operations to transform the matrix into an upper triangular form. After performing these operations, we get the following matrix:
[0 1/4 1/4 | 1+pi]
From this, we can see that the system has a unique solution for x, y, and z. Using back substitution, we can solve for x, y, and z in terms of pi.
I hope this helps you understand how to use matrices to solve systems of equations. Keep up the self-studying and good luck with your future studies!
FAQ: Solution to complicated systems of three variables using matrices
How do I solve a complicated system of three variables using matrices?
To solve a complicated system of three variables using matrices, you can use the method of Gaussian elimination. This involves converting the system into an augmented matrix, applying row operations to simplify the matrix, and then using back substitution to find the values of the variables.
Can I use matrices to solve any system of equations with three variables?
Yes, matrices can be used to solve any system of equations with three variables. However, the complexity of the system may affect the difficulty of the solution process.
Is it possible to have more than one solution to a system of three variables?
Yes, it is possible to have more than one solution to a system of three variables. This is known as an infinite solution, where the three variables are not uniquely determined by the equations.
What happens if the system of three variables is inconsistent?
If the system of three variables is inconsistent, it means that there is no solution that satisfies all the equations. In this case, the matrix will have a row of zeros and the system cannot be solved using the method of Gaussian elimination.
Can I use matrices to solve systems of equations with more than three variables?
Yes, matrices can also be used to solve systems of equations with more than three variables. The process is similar to solving a system of three variables, but it may be more complex and time-consuming.
