roni1
- 20
Why we can't use radical to solve an equations with power greater than 4?
A solution to a function with power greater than 4 is a value or set of values that satisfy the equation when substituted into the function.
To solve a function with power greater than 4, you can use various methods such as factoring, graphing, or using the quadratic formula depending on the specific function and its form.
Yes, a function with power greater than 4 can have multiple solutions, especially if it is a polynomial function. These solutions may be real or complex numbers.
To check if a value is a solution to a function with power greater than 4, simply substitute the value into the function and see if it satisfies the equation. If the output is equal to the input, then the value is a solution.
Yes, a function with power greater than 4 can have no solutions. This can occur if the function is undefined for all values or if the solutions are complex numbers and the function only deals with real numbers.
