MHB Solution to Infinite series for E^(n^2x)
The discussion focuses on finding a solution to the infinite series for e^(n^2x) that can be implemented in Excel or a VBA script. A user seeks assistance with the n^-2 term in the series, having previously understood e^-(n^2y). Suggestions include using a loop to sum terms until they fall below a specified threshold for accuracy or employing array formulas in Excel to calculate the series up to a certain n value. The importance of experimenting with iterations to ensure accuracy is emphasized. Overall, the conversation aims to provide practical methods for solving the mathematical problem related to gas flow through porous media.
IanM
This is my first time posting so forgive me if I have it in the wrong place,
i'm trying to find a solution to the following that I can stick into either excel or a VBA script. It has been 25 years since I looked at any serious maths and I'm stumped. I can find and digest e^-(n^2y) but can't work out the n^-2 addition. Happy to be walked though the steps if it helps me get a better understanding, for those interested it is part of a solution to determine the ability for gas to flow though a porous medium
Cheers
Ian
Mathematics news on Phys.org
Cheers
Ian
Hi IanM,
The usual way to make an approximation is to keep summing subsequent terms until the next term is below a certain threshold.
Something like:
Code:
n = 0
sum = 0
do
  n = n + 1
  term = (6 / pi) * exp(-(pi^2) * (n^2) * Kt / rs) / n^2
  sum = sum + term
while term > 0.0001
That will give us a result that is accurate up to the first 4 digits after the dot.
We'd have to look up how to do that in VBA exactly.
Alternatively, we can create a fixed column of numbers of, say, 1..10 in cells A1:A10.
And calculate the result up to $n=10$ as:
[M]=SUM((6/PI()) * EXP(-3*$A$1:$A10^2)/$A$1:$A10^2)[/M]
Use Ctrl+Shift+Enter when entering the formula, making it an array-formula.
Afterwards, it will show up as:
[M]{=SUM((6/PI()) * EXP(-3*$A$1:$A10^2)/$A$1:$A10^2)}[/M]
Or even fancier in a single cell:
[M]{=SUM((6/PI()) * EXP(-3*{1,2,3,4,5}^2)/{1,2,3,4,5}^2)}[/M]
(Don't forget Ctrl+Shift+Enter.)
We'll have to experiment a bit to see how many iterations are enough.
We could check whether
[M]{=SUM((6/PI()) * EXP(-3*{1,2,3,4,5,6}^2)/{1,2,3,4,5,6}^2) - SUM((6/PI()) * EXP(-3*{1,2,3,4,5}^2)/{1,2,3,4,5}^2)}[/M]
can be considered small enough. This is the indicator for the error in the result.
Fantastic thanks for the Help, even better it makes sense!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
