Solution to POTW #207: Evaluate x^{16}-987x for \sqrt{2}<x<\sqrt{3}
  • MHB
  • Thread starter anemone
  • Tags
    2016
In summary, the purpose of this problem is to evaluate the given expression, x^16-987x, for values of x between √2 and √3. To solve this problem, you can first simplify the expression by factoring out x and then use the given range of x values to determine the sign of the resulting expression. The range √2 < x < √3 is significant as it helps to narrow down the possible solutions and provides a specific context for the problem. You can use a calculator to solve this problem, but it is important to show your work and explain your steps. To check your solution, you can plug the value of x into the original expression or use a graphing calculator to visually verify it
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Let $a$ be a positive number and we show decimal part of the $a$ with $\{a\}$.
For a positive number $x$ with $\sqrt{2}<x<\sqrt{3}$ such that \(\displaystyle \{\frac{1}{x}\}=\{x^2\}\), evaluate $x^{16}-987x.$
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution::)
1. kaliprasad
2. greg1313
3. lfdahl
Solution from kaliprasad:
Because $ x> 1$ so $\frac{1}{x} < 1$ and hence $\lbrace \frac{1}{x} \rbrace = \frac{1}{x}$
Because $\sqrt{2} < x < \sqrt{3}$ hence $ 2 < x^2 < 3$ hence $\lbrace x^2 \rbrace = x^2 - 2$
hence $\frac{1}{x} = x^2-2$
or $ x^3-2x = 1$ or $(x+1)(x^2-x-1) = 0$ or $x^2 = x + 1$ as $x > 0$
$=>x^4 = (x+1)^2 = x^2 + 2x + 1 = (x+1)+(2x+1) = 3x + 2$
$=>x^8 = (3x+2)^2 = 9x^2 + 12 x + 4 = 9(x+1) + 12 x + 4 = 21x + 13$
$=>x^{16} = (21x+13)^2 = 441x^2 + 546 x + 169 = 441(x+1) + 546 x + 169 = 987 x + 610$
or $x^{16} - 987 x = 610$
Alternate solution from lfdahl:
Let $d$ denote the decimal part of $x^2$: $x^2 = 2+d = 2+\left \{ x^2 \right \} = 2+\left \{ \frac{1}{x} \right \}$.
$\left \{ x^2 \right \} = \left \{ \frac{1}{x} \right \} \Rightarrow d = \frac{1}{\sqrt{2+d}} \Rightarrow d^3+2d^2-1 = 0$
$d = -1$ is one of the roots in the cubic expression. Polynomial division yields:
\[d^3+2d^2-1 = (d+1)(d^2+d-1)\]
The set of solutions is:
\[d \in \left \{ -1, \frac{\sqrt{5}-1}{2}, \frac{-\sqrt{5}-1}{2} \right \}\]
From $d = \frac{1}{x} = \frac{\sqrt{5}-1}{2}$, we get: $x = \frac{\sqrt{5}+1}{2} $
So the $x$ in question is the famous golden ratio, $\varphi$.
One of the beautiful relations of the golden ratio involves Fibonacci numbers:
$\varphi^n = F_n\varphi + F_{n-1}$
In order to find $\varphi^{16}$, we simply use the 15th and 16th Fibonacci number:
\[\left \{ \underbrace{1}_{F_1},\underbrace{1}_{F_2},2,3,5,8,13,21,34,55,89,144,233,377,\underbrace{610}_{F_{15}}, \underbrace{987}_{F_{16}},1597, 2584 . . . \right \}\]
$\varphi^{16}=987\varphi + 610$
Thus we end with the result: $\varphi^{16}- 987\varphi = F_{15}= 610$.
FAQ: Solution to POTW #207: Evaluate x^{16}-987x for \sqrt{2}<x<\sqrt{3}
What is the purpose of this problem?
The purpose of this problem is to evaluate the given expression, x16-987x, for values of x between √2 and √3. This exercise helps to practice applying mathematical operations and concepts, such as exponent rules and inequality notation.
How do I approach solving this problem?
To solve this problem, you can first simplify the expression by factoring out x. Then, you can use the given range of x values to determine the sign of the resulting expression and evaluate it accordingly.
What is the significance of the given range for x?
The range √2 < x < √3 is significant because it limits the possible values of x to be between the square roots of 2 and 3. This range helps to narrow down the possible solutions and provides a specific context for the problem.
Can I use a calculator to solve this problem?
Yes, you can use a calculator to evaluate the expression for different values of x within the given range. However, it is important to show your work and explain your steps in solving the problem.
How can I check my solution?
You can check your solution by plugging the value of x into the original expression and comparing it to the result of your evaluation. You can also use a graphing calculator to plot the expression and visually verify your solution.
