MHB Solution to Trigonometric System
The discussion focuses on finding real values of x, y, and z within the interval [0, π/2] that satisfy the trigonometric equations sin(x)cos(y) = sin(z) and cos(x)sin(y) = cos(z). Participants evaluate different approaches to solving the system, with one user acknowledging another's method while pointing out an oversight in identifying all possible solutions. The conversation highlights the collaborative nature of problem-solving in mathematics, as users share insights and corrections. Ultimately, the aim is to identify all valid pairs of solutions to the given equations. The thread emphasizes the importance of thoroughness in mathematical problem-solving.
anemone
MHB
POTW Director
Find all reals $$x,\,y,\,z \in \left[0,\,\frac{\pi}{2}\right]$$ that satisfying the system below:
$\sin x \cos y=\sin z\\\cos x \sin y=\cos z$
Mathematics news on Phys.org
I can find only one solution:
Taking a square and summing up will get
$$\begin{align*}\sin^2 z + \cos^2 z = 1 &= \sin^2x\cos^2y + \cos^2x\sin^2y \\
& = \sin^2x + \sin^2y \left( \cos^2x - \sin^2x \right) \qquad \Rightarrow \end{align*} $$
$$\sin^2y = \frac{\cos^2x}{\cos^2x - \sin^2x} \ge 1.$$
Equality takes place when $$x = 0$$ and thus $$y = \frac{\pi}{2}$$ and $$z = 0$$ is the only solution.
We have $(\sin x \cos y)^2+(\cos x \sin y)^2 =1$\
$(\sin x \cos y)^2 <= (\sin x)^2$ and $(\sin x \cos y)^2 <= (\cos y)^2$
so on we must have
either$(\sin x \cos y) = (\sin x)$ and $(\cos x \sin y) = \cos x$ $=>\sin x = 0,\sin y = 1$ or $\cos y = 1,\cos x=0$
This gives
1) $\sin x = 0,\sin y = 1$ => $x=0, y = \frac{\pi}{2}, z= 0$
2) $\cos x = 0,\cos y = 1$ => $x=z = \frac{\pi}{2}, y= 0$
Or $(\sin x \cos y) = (\cos y )$ and $(\cos x \sin y) = \sin y$ $=>\cos x = 1,\cos y = 0$ or $\sin y = 1,\cos x=1$
THis does not gives any additional solutions
so the solution set is
3)$x=0, y = \frac{\pi}{2}, z= 0$ or $x=z = \frac{\pi}{2}, y= 0$
- - - Updated - - -
Hello Theia;
your approach is better than my approach but unfortunately you overlooked
$\sin \,y = \cos\, x = 0$
Hi Theia!
Albeit you missed out another pair of solution, you still deserve a pat on the back for the job well done...and thanks for participating!
My solution:
Adding up the two equations gives:
$\sin z+\cos z=\sin x \cos y+\cos x \sin y$
Now, by applying the Cauchy-Schwarz inequality to the RHS of equation above yields:
$\sin z+\cos z=\sin x \cos y+\cos x \sin y\le \sqrt{\sin^2 x+\cos^2 x} \sqrt{\sin^2 y+\cos^2 y}=1$
$\left(\sin z+\cos z\right)^2\le 1^2$
$\sin^2 z+\cos^2 z+2\sin z \cos z\le 1^2$
$\sin z \cos z\le 0$ (*)
But since we're told $$x,\,y,\,z \in \left[0,\,\frac{\pi}{2}\right]$$, the inequality (*) holds iff $\sin z=0$ or $\cos z=0$, which lead to two set of solutions where:
$$\left(x,\,y,\,z\right)=\left(0,\,\frac{\pi}{2},\,0\right),\,\left(\frac{\pi}{2},\,0,\,\frac{\pi}{2}\right)$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
