Solutions effect of dilution will not take place?
  • Thread starter zorro
  • Tags
    Dilution
In summary, the question asks which of the following solutions will not experience a change in pH due to dilution. The correct answers are A, C, and D, as these solutions are buffers or have a constant pH after dilution. Solution B, which is a solution of salt of a weak acid, will experience a change in pH after dilution. Solution D, which is a solution of a salt of a weak acid and a weak base, has a constant pH after dilution.
zorro
1,384
Multiple Choice-
In which of the following solutions effect of dilution will not take place??
(A) 100 ml 0.1 M CH3COOH with 50 ml 0.1 M NaOH
(B) 100 ml 0.1 M CH3COOH with 100 ml 0.1 M NaOH
(C) 100 ml 0.1 M CH3COOH with 50 ml 0.1 M NH4OH
(D) 100 ml 0.1 M CH3COOH with 100 ml 0.1 M NH4OH
I think the answer is B and D because the solutions will be neutralised and there won't be any effect on dilution.
But the answer given is A and D.
Help
No idea what the question asks. Dilution of what? Effect on what?
Dilution of the solution which is obtained after mixing the liquids in given options.
Effect on pH of the solution.
Question still doesn't make sense to me. If you mix solution of acid with solution of base, final pH will be always different from pH of original solutions.
So far question asks to compare apples and oranges.
Look- after mixing the two solutions, let the pH of the resulting solution be x
Now on adding water, will the pH be x or different?
I hope you understood.
OK, got it. Not necessarily the best wording, I was all the time thinking about dilution that takes place when solutions are mixed.
Not only wording is poor, also answer is incorrect. Usually I would help you to solve the question on your own, but I have no idea what the expected answer is.
The only solution that has constant pH is the last one - that is, ammonium acetate.
Solution A: pH after mixed 4.67, after diluted with 100 mL of water - 4.69
Solution B: pH after mixed 8.63, after diluted with 100 mL of water - 8.56
Solution C: pH after mixed 4.67, after diluted with 100 mL of water - 4.69
Solution D: pH after mixed 7.00, after diluted with 100 mL of water - 7.00
You may have troubles getting these numbers, as they take ionic strengths into account (I have calculated them using this pH calculator). When ionic strengths are ignored calculated pH values are:
Solution A: pH after mixed 4.76, after diluted with 100 mL of water - 4.76
Solution B: pH after mixed 8.71, after diluted with 100 mL of water - 8.63
Solution C: pH after mixed 4.76, after diluted with 100 mL of water - 4.76
A & C are buffers, so their pH is more or less constant. Solution B is a solution of salt of a weak acid, which is equivalent to solution of a weak base, its pH is obviously dependent on the concentration. Solution D is a funny case of solution of a salt of a weak acid and a weak base - funny, as they are both weak in exactly the same degree, so effects of their hydrolysis cancel out.
Even after mixing water, the pH is constant right? then why D is not a correct option?
D is correct, but if you have to select correct ones, A & D are not all that are correct - A, C & D are. Hence A & D is not the correct answer.
Thanks Mr.PH!
FAQ: Solutions effect of dilution will not take place?
1. What is the effect of dilution on a solution?
Dilution is the process of adding more solvent to a solution, which decreases the concentration of the solute. The main effect of dilution on a solution is that it reduces the concentration of the solute and makes the solution more diluted.
2. Will the dilution of a solution affect its chemical properties?
Yes, dilution can affect the chemical properties of a solution. By decreasing the concentration of the solute, the reactivity and ability of the solution to undergo chemical reactions may also be reduced.
3. How does dilution affect the pH of a solution?
Dilution can affect the pH of a solution by changing the concentration of hydrogen ions (H+) and hydroxide ions (OH-) in the solution. If the solute is an acid or base, dilution can change the pH of the solution depending on the strength of the acid or base.
4. Is dilution a reversible process?
Yes, dilution is a reversible process. If more solute is added to a diluted solution, the concentration of the solute will increase and the solution will become more concentrated. This process can be repeated multiple times.
5. How does dilution affect the volume of a solution?
Dilution increases the volume of a solution by adding more solvent. This means that a given amount of solute will occupy a larger volume in a diluted solution compared to a concentrated solution.
