MHB Solutions of DE System & 2nd Order Differential Equation
WMDhamnekar
MHB
Hello,
$\vec{x'}=\small\begin{pmatrix}1&2\\3&2\end{pmatrix}\vec{x}+t\small\begin{pmatrix}2\\-4\end{pmatrix}$
Now i got the solution to this differential equation system as
$\vec{x}(t)=c_1e^{-t}\small\begin{pmatrix}-1\\1\end{pmatrix}$+$c_2e^{4t}\small\begin{pmatrix}2\\3\end{pmatrix}$+$t\small\begin{pmatrix}3\\\frac{-5}{2}\end{pmatrix}$+$\small\begin{pmatrix}-2.75\\2.875\end{pmatrix}$
Now i converted this differential equation system into ordinary differential equation $y''-3y'-4y+12t-2=0$
I got solution to this DE as $y=C_1e^{-x}+C_2e^{4x}+3t-\frac12$.
Now my question why there is diference in these two solutions?
Dhamnekar Winod said:
Hello,
Hi Dhamnekar Winod, welcome to MHB! ;)
Your solution contains $x$ on the right hand side. I presume it should be $t$?
Either way, if I feed the latter equation to Wolfram|Alpha, I get:
$$y(t)=c_1e^{-t}+c_2e^{4t}+3t-\frac{11}{4}$$
So:
  • It seems to be the solution for $x(t)$ rather than $y(t)$.
  • Your equation is correct, although for $x(t)$ rather than $y(t)$.
  • There is a minor arithmetic mistake somewhere in your solution.
Hello, The derivative of $x_1=C_1e^{-t}+C_23e^{4t}-2.5t+2.875$in the differential equation system.But in the second case,it is different Why?
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
