MHB Solutions of Diophantine equations of Legendre.
  • Thread starter Thread starter individ
    Legendre
The discussion centers on the solutions to Diophantine equations of Legendre, specifically questioning whether the derived formulas encompass all possible solutions. Despite the complexity of the formulas, no counterexamples have been found, indicating their potential validity. The conversation highlights the necessity of identifying equivalent quadratic forms when integer roots are absent, suggesting that transformations can lead to solvable equations. The formulas, while daunting, are presented as essential tools for tackling these mathematical challenges. Understanding and applying these formulas is emphasized as crucial for effectively solving Diophantine equations.
individ
The problem is that when I got the formula that led below - there was a question whether they really describe all the decisions?
But has not yet found a counterexample, and it exists at all interested or not?
Although the discussion of this issue in many other forums and did not work. Everyone really does not like a lot of formula.
Here are the formulas. Formula generally look like this: Do not like these formulas. But this does not mean that we should not draw them. To start this equation zayimemsya, well then, and others.
$$aX^2+bXY+cY^2=jZ^2$$
Solutions can be written if even a single root. $$\sqrt{j(a+b+c)}$$ , $$\sqrt{b^2 + 4a(j-c)}$$ , $$\sqrt{b^2+4c(j-a)}$$
Then the solution can be written.
$$X=(2j(b+2c)^2-(b^2+4c(j-a))(j\pm\sqrt{j(a+b+c)}))s^2+2(b+2c)(\sqrt{j(a+b+c)}\mp{j})sp+ +(j\mp \sqrt{j(a+b+c)})p^2$$
$$Y=(2j(2j-b-2a)(b+2c)-(b^2+4c(j-a))(j\pm\sqrt{j(a+b+c)}))s^2+ +2((2j-2a-b)\sqrt{j(a+b+c)}\mp{j(b+2c)})sp+(j\mp\sqrt{j(a+b+c)})p^2$$
$$Z=(2j(b+2c)^2-(b^2+4c(j-a))(a+b+c\pm\sqrt{j(a+b+c)}))s^2+2(b+2c)(\sqrt{j(a+b+c)}\mp{j})sp+( a + b + c \mp \sqrt{j(a+b+c)})p^2$$
In the case when the root $$\sqrt{b^2+4c(j-a)}$$ whole.
Solutions have the form.
$$X=((2j-b-2c)(8ac+2b(2j-b))-(b^2+4a(j-c))(b+2c\mp\sqrt{b^2+4c(j-a)}))s^2+ +2(4ac+b(2j-b)\pm{(2j-b-2c)}\sqrt{b^2+4c(j-a)})sp+(b+2c\pm\sqrt{b^2+4c(j-a)})p^2$$
$$Y=((b+2a)(8ac+2b(2j-b))-(b^2+4a(j-c))(2j-b-2a\mp\sqrt{b^2+4c(j-a)}))s^2+ +2(4ac+b(2j-b)\pm{(b+2a)}\sqrt{b^2+4c(j-a)})sp+(2j-b-2a\pm\sqrt{b^2+4c(j-a)})p^2$$
$$Z=((b+2a)(8ac+2b(2j-b))-(b^2+4a(j-c))(b+2c\mp\sqrt{b^2+4c(j-a)}))s^2+ +2(4ac+b(2j-b)\pm {(b+2a)}\sqrt{b^2+4c(j-a)})sp+(b+2c\pm\sqrt{b^2+4c(j-a)})p^2$$
In the case when the root $$\sqrt{b^2+4a(j-c)}$$ whole.
$$X=(2j^2(b+2a)-j(a+b+c)(2j-2c-b\pm\sqrt{b^2+4a(j-c)}))p^2+2j(\sqrt{b^2+4a(j-c)}\mp{(b+2a)})ps++(2j-2c-b\mp\sqrt{b^2+4a(j-c)})s^2$$
$$Y=(2j^2(b+2a)-j(a+b+c)(b+2a\pm\sqrt{b^2+4a(j-c)}))p^2 +2j(\sqrt{b^2+4a(j-c)}\mp{(b+2a)})ps+ +(b+2a\mp\sqrt{b^2+4a(j-c)})s^2$$
$$Z=j(a+b+c)(b+2a\mp\sqrt{b^2+4a(j-c)})p^2+2((a+b+c)\sqrt{b^2+4a(j-c)}\mp{j(b+2a)})ps+ + (b+2a\mp\sqrt{b^2+4a(j-c)})s^2$$
Since these formulas are written in general terms, require a certain specificity calculations.If, after a permutation of the coefficients, no root is not an integer. You need to check whether there is an equivalent quadratic form in which, at least one root of a whole. Is usually sufficient to make the substitution $$X\longrightarrow{X+kY}$$ or more $$Y\longrightarrow{Y+kX}$$ In fact, this reduces to determining the existence of solutions in certain Pell's equation. Of course with such an idea can solve more complex equations. If I will not disturb anybody, slowly formula will draw. number $$p,s$$ integers and set us. I understand that these formulas do not like. And when they draw - or try to ignore or delete.
Formulas but there are no bad or good. They either are or they are not.
In equation $$aX^2+bY^2+cZ^2=qXY+dXZ+tYZ$$
$$a,b,c,q,d,t$$ integer coefficients which specify the conditions of the problem.
For a more compact notation, we introduce a replacement.
$$k=(q+t)^2-4b(a+c-d)$$
$$j=(d+t)^2-4c(a+b-q)$$
$$n=t(2a-t-d-q)+(2b-q)(2c-d)$$
Then the formula in the general form is:
$$X=(2n(2c-d-t)+j(q+t-2b\pm\sqrt{k}))p^2+2((d+t-2c)\sqrt{k}\mp{n})ps+(2b-q-t\pm\sqrt{k})s^2$$
$$Y=(2n(2c-d-t)+j(2(a+c-d)-q-t\pm\sqrt{k}))p^2+2((d+t-2c)\sqrt{k}\mp{ n })ps+ +(q+t+2(d-a-c)\pm\sqrt{k})s^2$$
$$Z=(j(q+t-2b\pm\sqrt{k})-2n(2(a+b-q)-d-t))p^2+2((2(a+b-q)-d-t)\sqrt{k}\mp{n})ps+ +(2b-q-t\pm\sqrt{k})s^2$$
And more.
$$X=(2n(q+t-2b)+k(2c-d-t\pm\sqrt{j}))p^2+2((2b-q-t)\sqrt{j}\mp{n})ps+(d+t-2c\pm\sqrt{j})s^2$$
$$Y=(2n(2(a+c-d)-q-t)+k(2c-d-t\pm\sqrt{j}))p^2+2((q+t+2(d-a-c))\sqrt{j}\mp{n})ps+ +(d+t-2c\pm\sqrt{j})s^2$$
$$Z=(2n(q+t-2b)+k(d+t+2(q-a-b)\pm\sqrt{j}))p^2+2((2b-q-t)\sqrt{j}\mp{n})ps+ +(2(a+b-q)-d-t\pm\sqrt{j})s^2$$
Since formulas are written in general terms, in the case where neither the root is not an integer, it is necessary to check whether there is such an equivalent quadratic form in which at least one root of a whole. If not, then the solution in integers of the equation have not.
Mathematics news on Phys.org
But if there is an equivalent form in which at least one root is a whole, then it is possible to apply the above formulas. Therefore, these formulas are not just a set of complex mathematical symbols, but a powerful tool for solving Diophantine equations of Legendre. They may seem intimidating at first, but with practice and understanding of the underlying principles, they can be a valuable asset in solving difficult problems. So, it is important to not dismiss these formulas simply because they may seem complicated, but to take the time to understand and utilize them in problem-solving.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
