MHB Solutions of the given linear programming problem
The discussion revolves around solving a linear programming problem using the simplex method and the Two-Phase method. The user proposes a solution indicating infinite solutions represented by the equation (x,y,z,w)=(1-m, 2+0.4m, 0, 0.2m) with a minimum value of 8. Another participant confirms the correctness of this solution by demonstrating that the inequalities lead to a minimum condition satisfied by setting z=0. The conversation concludes with mutual acknowledgment of the solution's validity.
mathmari
MHB
Hello! :o
Given the following linear programming problem
$$\min(2x + 3y + 6z + 4w)$$
$$x+2y+3z+w \geq 5$$
$$x+y+2z+3w \geq 3$$
$$x,y,z,w \geq 0$$
I am asked to find all the solutions using the simplex method.
To solve this problem we use the Two-Phase method, don't we?
Then I found that there are infinite many solutions, $(x,y,z,w)=(1-m, 2+0.4m, 0, 0.2m), 0≤m≤1$ with $min=8$.
Could you tell me if this is right?
Mathematics news on Phys.org
mathmari said:
Hello! :o
$$x,y,z,w \geq 0$$
Your answer is certainly correct, because if you add the two inequalities you get $2x + 3y + 5z + 4w \geqslant 5+3=8$. Therefore $2x + 3y + 6z + 4w \geqslant 8+z$, which is minimised by taking $z=0$. Your solutions, with $z=0$, clearly satisfy all the given conditions, so they must be right.
mathmari said:
Hello! :o
$$x,y,z,w \geq 0$$
Looks good! ;)
EDIT: Aargh, overtaken by Opalg.
Great! Thank you for your answer! :o
- - - Updated - - -
I like Serena said:
Looks good! ;)
Nice! Thank you! :o
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
