- #36
Chris Hillman
- 10
Electrovacuum =/= Vacuum
Hi, notknowing,
Well, if you know the math such statements are trying to describe, they have some value, but yes, this is just one illustration of why popular descriptions are almost always terribly misleading in some ways.
Well, I don't know why you say "magic" unless gravitation is "magical". No-one was claiming (or if they did, they probably should not have) that matter is "transformed to pure gravitational energy", unless that is how you want to summarize the discussion in the FAQ "How does gravity get out of a black hole?" and in my long extinct but archived post to sci.physics (both cited in a post to this forum made earlier today, 25 November--- happy birthday, gtr!).
I am not sure what you mean by your remark about quantum gravity. If you meant that quantum gravity should prevent the formation of an event horizon, that is probably not true. If you mean that quantum gravity should drastically alter physics as sectional curvatures approach the reciprocal of the Planck length squared, that is almost certainly true, although we won't know the details until a successful theory appears (and is understood at least in its most basic respects).
The stress-energy tensor is NOT identically zero outside a charged black hole! That is because the electromagnetic field contributes a nonzero term to the stress-energy. This is why we speak of "electrovacuum" rather than "vacuum" in a region where an electromagnetic field but no matter or other non-gravitational fields are present.
In the case of a charged object such as a hollow spherical metallic shell with uniformly distributed charge (for example), the charge is located on the surface just as you would expect from Maxwell. This would be modeled by an electrovacuum exterior (a portion of the Reissner-Nordstrom electrovacuum) matched to a charged spherical shell (which we can model as "infinitely thin" for convenience) and to a vacuum interior (a portion of the Minkowksi vacuum, since there is no electric or gravitational field inside the shell, as in pre-relativistic physics).
Chris Hillman
Hi, notknowing,
notknowing said:I was mislead by the popular view that in a black hole a point of infinite density is obtained.
notknowing said:I recapitulate things to see if I understand it correctly. First you need a sufficient amount of mass to create a black hole in the first place ("feed" it). Then, through some magic, the matter is crunched together in such a way that it is transformed into pure gravitational energy such that "the curvature itself becomes the source of curvature" (the idea which I had originally to create a kind of "geon"). Of course, in a quantum theory of gravitation, things would probably turn out to be very different.
notknowing said:But what then about a charged black hole ? If the stress-energy tensor is also congruently zero everywhere in this case, such that one can not speek of mass in the usual sense, where is then the charge located ? It can probably not be considered to be "smeared out" in the region inside the horizon ?
Chris Hillman
