MHB Solutions to Bessel's equation with Wolfram
  • Thread starter Thread starter Joppy
Joppy
MHB
Hi
Why does Wolfram find the solution of Bessels equation with non-integer $\nu$ to be of the form $y = c_1 J_\nu + c_2 Y_\nu$. I thought Bessels function of the second kind only arose in situations were $\nu$ is an integer. What's going on here? Thanks :).
As an example, see here.
I don't know where you got that idea. Bessel's equation, for any \nu, is a second order differential equation so has two independent solutions, one of which is singular at the origin. That one is the "Bessel's function of the second kind".
I don't know where you got the idea that your response constitutes any sort of answer.
It stated in numerous texts that the general solution to Bessels equation with non-integer $\nu$ is given by, $y(x) = c_1 J_{\nu} + c_2 J_{-\nu}$, two linearly independent solutions.
When Bessels function of the second kind is introduced we then say that a general solution for all x>0 is $y(x) = c_1 J_{\nu} + c_2 Y_{\nu}$, as you have said. I realize that $Y_{\nu}$ includes both Bessels function of the first kind of order $\nu$ and $\-nu$, but this doesn't make them equivalent.
So, again, my question. Why, in the link in the OP, is the solution not of the form $y(x) = c_1 J_{\nu} + c_2 J_{-\nu}$, since $\nu$ is non-integer.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
