Solutions to x^3+...+y^3=y^3 in Integers
  • MHB
  • Thread starter anemone
  • Tags
    Integers
In summary, the only solutions in integers for the equation given are $(-5, -6)$, $(-4, -4)$, $(-3, 4)$, and $(-2, 6)$.
anemone
MHB
POTW Director
3,883
115
Find all solutions in integers of the equation
\(\displaystyle x^3+(x+1)^3+(x+2)^3+\cdots+(x+7)^3=y^3\)
Mathematics news on Phys.org
[sp]$x^3+(x+1)^3+(x+2)^3+\cdots+(x+7)^3=8x^3 + 84x^2 + 420x + 784 = (2x+7)(4x^2 + 28x + 112) = z(z^2+63)$, where $z=2x+7$. Thus $z$ is an odd integer and $z(z^2+63) = y^3$. If $(y,z)$ is a solution then so is $(-y,-z)$, so concentrate on the case where $y$ and $z$ are both positive. Since $y^3 = z^3 + 63z$ it is clear that $y>z$ and so $y\geqslant z+1$. Therefore $z^3+63z \geqslant (z+1)^3 = z^3 + 3z^2 + 3z + 1$, so that $3z^2 -60z + 1 \leqslant 0.$ Writing this as $3z(z-20) + 1 \leqslant 0$, you see that $z<20$. When you check the odd numbers from $1$ to $19$, you find that the only solutions are when $z=1$ and $z=3$. Thus the solutions (including the negative ones) for $(y,z)$ are $(\pm4,\pm1)$ and $(\pm6,\pm3)$; and the solutions for $(x,y)$ are $(-5,-6),\: (-4,-4),\: (-3,4),\:(-2,6).$[/sp]
Thanks Opalg for participating and you have gotten all 4 correct solutions!
Here is the method I saw somewhere that is different from that of Opalg and I wish to share it here...
Let \(\displaystyle f(x)=x^3+(x+1)^3+(x+2)^3+(x+3)^3+(x+4)^3+(x+5)^3+(x+6)^3+(x+7)^3=8x^3+84x^2+420x+784=y^3\)
Also
\(\displaystyle (2x+7)^3=8x^3+84x^2+294x+343\)
\(\displaystyle (2x+10)^3=8x^3+120x^2+600x+1000\)
If $x\ge 0$, we can say that \(\displaystyle (2x+7)^3<f(x)<(2x+10)^3\).
This implies \(\displaystyle (2x+7)<y<(2x+10)\) and therefore $y$ is $2x+8$ or $2x+9$. But neither of the equations
\(\displaystyle f(x)-(2x+8)^3=-12x^2+36x+272=0\)
\(\displaystyle f(x)-(2x+9)^3=-24x^2-66x+55=0\)
have integer roots.
So we can conclude that there is no solution with $x\ge 0$.
Notice also that if we replace $x$ by $-x-7$, we end up having \(\displaystyle f(-x-7)=-f(x)\). This means $(x, y)$ is a solution iff $(-x-7, -y)$ is a solution. Therefore, there are no solution with $x\le -7$. Therefore, for $(x, y)$ to be a solution, we must have $-6 \le x \le -1$.
Checking all possibilities out lead us to the only 4 solutions, and they are $(-2, 6)$, $(-3, 4)$, $(-4, -4)$ and $(-5, -6)$.
$\vdots$
Notice that if you put $x=-3$ in the formula for $f(x)$ then it becomes $(-3)^3 + (-2)^3 + (-1)^3 + 0^3 + 1^3 + 2^3 + 3^3 + 4^3$. All the negative terms cancel with positive terms and you are just left with $4^3$.
If you put $x=-2$ then you get $f(-2) = (-2)^3 + (-1)^3 + 0^3 + 1^3 + 2^3 + 3^3 + 4^3 + 5^3$. Again, the negative terms cancel with some of the positive ones, and the remaining terms illustrate the fact that $3^3 + 4^3 + 5^3 = 6^3.$
The other two solutions for $x$ work in a similar way, except that in these cases the negative terms outweigh the positive ones.
The equation x^3+(x+1)^3+(x+2)^3+\cdots+(x+7)^3=y^3 represents a Diophantine equation, which is a type of mathematical equation that involves finding integer solutions. In this case, we are looking for solutions in the form of integers for both x and y.
To find all solutions, we can approach this problem using various methods such as brute force, algebraic manipulation, or number theory techniques. One possible method is to start with a specific value for x and find the corresponding value for y, then continue to iterate through different values of x until all solutions have been found.
Another approach is to use number theory techniques, such as the Pythagorean triples method, to find solutions. This method involves finding three integers, a, b, and c, such that a^2+b^2=c^2. In this case, we can rewrite the equation as (x+3)^3+(x+4)^3+(x+5)^3=(x+6)^3, which can be solved using the Pythagorean triples method.
It is important to note that this equation has an infinite number of solutions, as there are an infinite number of combinations of integers that can satisfy the equation. Therefore, it is not possible to list all solutions, but rather to provide a method for finding them.
In conclusion, finding solutions to x^3+...+y^3=y^3 in integers requires a systematic approach and may involve various mathematical techniques. It is an interesting problem that can be explored further using different methods and can lead to a deeper understanding of number theory and Diophantine equations.
FAQ: Solutions to x^3+...+y^3=y^3 in Integers
What does "solutions to x^3+...+y^3=y^3 in Integers" mean?
"Solutions to x^3+...+y^3=y^3 in Integers" refers to finding values for the variables x and y that satisfy the equation when both x and y are integers (whole numbers).
How do you solve this equation?
This equation is known as a Diophantine equation, which is a type of equation where the variables are restricted to integers. One method to solve it is by using the method of infinite descent, where a solution is found by showing that a smaller solution can be found, leading to an infinite descent until a solution of 0 is reached. Another method is by using modular arithmetic to find congruences between the variables.
Are there any specific values for x and y that satisfy the equation?
Yes, there are infinitely many solutions to this equation. Some examples include x=1 and y=0, x=6 and y=3, and x=10 and y=-9. These solutions can be found by trial and error or by using the methods mentioned in the previous answer.
Can this equation be solved using a computer program?
Yes, this equation can be solved using a computer program. The program can use algorithms and mathematical methods to find solutions for x and y that satisfy the equation. However, due to the infinite number of solutions, the program may not be able to find all possible solutions.
What is the significance of solving this equation?
Solving this equation can have various applications in mathematics, such as in number theory and cryptography. It can also help in understanding the properties of integers and their relationships. Additionally, solving this equation can help in finding patterns and developing new mathematical techniques.
