Solvation of Ionic compound in water
In summary, when NaCl is dissolved in water, the resulting NaCl(aq) solution has different chemical properties from its constituents NaCl and H2O. This is due to the formation of hydration spheres that stabilize the individual ions. NaCl(aq) and NaCl(s) also have different structures, with the former having separated hydrated ions and the latter having a regular lattice. This difference in structure leads to different chemical properties such as reactivity and activity. Whether dissolving NaCl in water is considered a chemical reaction depends on the circumstances, as it is ultimately a part of physics.
SSG-E
60
TL;DR Summary
If the solution of "NaCl in water" a chemical reaction, then will the chemical properties of this solution differ than that of its constituents(NaCl and H2O)?
When you dissolve, for example, NaCl in water, then you get "NaCl in water" solution. Will the "NaCl in water " solution have different chemical properties from its constituents(NaCl and H2O)? i.e. is a "NaCl in water" solution a new compound with respect to NaCl or H2O ? And is the ion surrounded by water molecules (solvation shell) a new compound?
Chemistry news on Phys.org
At this level it's all physics (or phyical chemistry if you want) and the properties will differ. Example: conductivity, activity
You can look them up for NaCl, H2O and brine.
Likes BillTre
[Mentor Note -- Two cross-posted threads have now been merged. Please do not cross-post.]
Well when you dissolve the NaCl the resulting Na+ and Cl- ions are stabilised by water molecules, which form hydration spheres around the individual ions. When it's dissolved, you would just call it an aqueous solution of NaCl, i.e. NaCl(aq).
etotheipi said:
Well when you dissolve the NaCl the resulting Na+ and Cl- ions are stabilised by water molecules, which form hydration spheres around the individual ions. Whether or not the dissolution is exothermic or endothermic depends on the relative magnitudes of the lattice dissociation enthalpies and the hydration enthalpies. When it's dissolved, you would just call it an aqueous solution of NaCl, i.e. NaCl(aq).
Then does the ion surrounded by water molecules forms another compound?
NaCl(s) and NaCl(aq) are different structurally, if that's what you're asking. The former is a giant, regular, repeating lattice of ions (in this case, a face-centred cubic), whilst in the latter the ions have been separated from each other, and are hydrated by water molecules.
Likes Mayhem and SSG-E
Then the NaCl(aq) will have different chemical properties(reactivity,etc) than NaCl(s) right?
Things like reaction rates, activity coefficients, what-not all definitely depend on the phase!
Another example; attaching some electrodes to a pile of salt isn't going to do much, but if you dissolve it in water, you have an electrolytic cell.
Likes SSG-E
That's correct. However, it also applies to solid and molten NaCl but nobody would say that melting is a chemical reaction. Whether dissolving NaCl in water is considered to be a chemical reaction or not depends on the circumstances. If you do it for recrystallisation it is reather a pure physical process. If you mix the NaCl solution with an aqueous AgNO3 solution than it could be seen as a first reaction step.
At the end of the day chemistry is just a part of physics. It is not a surprise that it is sometimes difficulty to distinguish between them.
Likes etotheipi
Related to Solvation of Ionic compound in water
1. What is solvation?
Solvation is the process by which a solute (such as an ionic compound) is dissolved in a solvent (such as water) to form a solution. It involves the separation of individual ions from the solid lattice and their interaction with the solvent molecules.
2. Why do ionic compounds dissolve in water?
Ionic compounds are composed of positively and negatively charged ions. Water, being a polar molecule, is able to interact with these ions through electrostatic attraction. The positive end of the water molecule is attracted to the negative ion, while the negative end is attracted to the positive ion, leading to the dissolution of the ionic compound.
3. What factors affect the solvation of ionic compounds in water?
The solubility of an ionic compound in water is influenced by several factors, including the strength of the ionic bond, the size and charge of the ions, and the polarity of the solvent. Temperature and pressure can also affect the solvation process.
4. How does solvation affect the properties of ionic compounds?
Solvation can alter the physical and chemical properties of an ionic compound. For example, it can increase the conductivity of the solution, change the color and appearance of the compound, and affect its reactivity with other substances.
5. Can ionic compounds dissolve in other solvents besides water?
Yes, ionic compounds can dissolve in other polar solvents such as alcohols, ammonia, and acetic acid. However, the strength of the solvation process may differ depending on the solvent used, and some ionic compounds may not be soluble in certain solvents.
  • Chemistry
9K
  • Chemistry
  • Chemistry
