Solve 2-Particle Elastic Collision: Mass m & Final Velocity -v/5
In summary, the conversation is about a homework problem involving two particles undergoing an elastic collision. One particle is initially at rest while the other has an initial velocity and a final velocity of -v/5. The task is to find the mass of the second particle in relation to the first particle's mass. The conversation includes attempts at using equations to solve the problem and ends with one person successfully solving it.
I Like Pi
91
Hey, just doing some homework, and can't figure this one out
Two particles go through an elastic collision. One particle has mass, m, and is initially at rest, while the other particle has initial velocity, v, and final velocity, -v/5. What is the mass of the second particle relating to m.
Answer: 2m/3
What I'm confused about is because you have two unknowns, the final velocity of the resting particle, and the mass of the second particle..
i tried using
m1v1 + m2v2 = m1v1' + m2v2'
and .5m1(v1)2 + .5m2(v2)2 = .5m1(v1)2' + .5m2(v2)2'
that seems waay too confusing for a question with no values..
You can imagine that m and v are numerical values. Just plug in m1=m, v1=0 (initially in rest), v2=v, v2' = -v/5 into your equation and solve for m2/m.
ehild
ehild
yes :smile: i figured it out last night, and when I have time I'll post the answer up here, it's really long haha
thanks ehild!
Is it long really? :smile:
m2 v=m v'-m2v/5
m2 v2=m v'2+m2v'2/25
mv'=6/5 m2 v *
mv'2=24/25 m2v2 **
Divide equation ** by eq. *
v' = 4/5 v
Substitute for v' in eq.*.
ehild
Hello,
Thank you for reaching out for help with your homework problem. I am happy to assist you in finding the solution to this problem.
First, let's define some variables to make the problem easier to understand:
m1 = mass of first particle (initially at rest)
m2 = mass of second particle (initially moving with velocity v)
v1 = velocity of first particle after collision
v2 = velocity of second particle after collision
We can use the conservation of momentum and conservation of kinetic energy equations to solve for the unknowns:
Conservation of momentum: m1v1 + m2v2 = m1v1' + m2v2'
Since m1 is initially at rest, v1 = 0:
m2v2 - m2v2' = m1v1'
m2(v2 - v2') = m1v1'
Conservation of kinetic energy: 0.5m1v1^2 + 0.5m2v2^2 = 0.5m1v1'^2 + 0.5m2v2'^2
0 + 0.5m2v2^2 = 0.5m1v1'^2 + 0.5m2v2'^2
0.5m2v2^2 - 0.5m2v2'^2 = 0.5m1v1'^2
0.5m2(v2^2 - v2'^2) = 0.5m1v1'^2
Now, we can substitute the expression we found for m1v1' into the kinetic energy equation:
0.5m2(v2^2 - v2'^2) = 0.5(m2(v2 - v2')/(v2 - v2'))m1v1'^2
0.5m2(v2^2 - v2'^2) = 0.5(m1v1')m1v1'^2
0.5m2(v2^2 - v2'^2) = 0.5m1^2v1'^2
Now, we can solve for m2:
m2 = (0.5
FAQ: Solve 2-Particle Elastic Collision: Mass m & Final Velocity -v/5
What is a 2-particle elastic collision?
A 2-particle elastic collision is a type of collision between two objects where both kinetic energy and momentum are conserved. This means that the total kinetic energy and total momentum of the two objects before and after the collision remains the same.
What is the mass m in the equation?
The mass m in the equation refers to the mass of one of the objects involved in the collision. In a 2-particle collision, both objects have different masses, so it is important to specify which mass is being used in the calculation.
How do I find the final velocity of one of the objects?
To find the final velocity of one of the objects, you can use the equation v' = (m - M)/(m + M) * v, where v' is the final velocity, m is the mass of the object being calculated, M is the mass of the other object, and v is the initial velocity of the object being calculated.
What are the units for the final velocity?
The units for the final velocity will depend on the units used for the initial velocity and mass in the calculation. However, typically the units for the final velocity will be meters per second (m/s) or feet per second (ft/s).
Can the final velocity be negative?
Yes, the final velocity can be negative. This indicates that the object is moving in the opposite direction after the collision compared to its initial direction of motion.
