Solve ## 25x\equiv 15\pmod {29} ##.
  • Thread starter Thread starter Math100
The linear congruence 25x≡15 (mod 29) has a unique solution since gcd(25, 29) equals 1. The solution process involves transforming the equation to -4x≡15 (mod 29) and then simplifying to -28x≡105, which reduces to x≡18 (mod 29). Additionally, using Bézout's Identity, it is shown that 1 can be expressed in terms of 25 and 29, leading to the conclusion that the modular inverse of 25 is 7. Thus, the final solution confirms that x≡18 (mod 29) is valid and can be derived through different methods. The discussion emphasizes the reliability of the approach for coprime numbers.
Math100
Solve the following linear congruence:
None.
Consider the linear congruence ## 25x\equiv 15\pmod {29} ##.
By corollary, if ## gcd(a, n)=1 ##, then the linear congruence ## ax\equiv b\pmod {n} ## has
a unique solution modulo ## n ##.
Observe that ## gcd(25, 29)=1 ##.
This means that the linear congruence ## 25x\equiv 15\pmod {29} ## has a
Thus
\begin{align*}
&25x\equiv 15\pmod {29}\\
&-4x\equiv 15\pmod {29}\\
&-28x\equiv 105\equiv 18\pmod {29}.\\
\end{align*}
Therefore, ## x\equiv 18\pmod {29} ##.
Math100 said:
Homework Statement:: Solve the following linear congruence:
Relevant Equations:: None.
Thus
\begin{align*}
\end{align*}
Right.
The standard procedure uses the Euclidean division. Given any two numbers ##a,b## there are numbers ##x,y## such that ##\operatorname{gcd}(a,b)=xa+yb.## (Bézout's Identity)
\begin{align*}
29 &= 1\cdot 25 +4\\
25&= 6\cdot 4 +1\\
4&= 4\cdot 1 + 0
\end{align*}
So ##1=25 -6\cdot 4=25-6\cdot (29-1\cdot 25)= 25- 6\cdot 29 +6\cdot 25=-6\cdot 29 + 7\cdot 25.## This means modulo ##29## that ##1 \equiv 7\cdot 25 \pmod {29}## or ##25^{-1}\equiv 7\pmod {29}.##
Therefore ##x\equiv 25^{-1} \cdot 15 \equiv7\cdot 15 \equiv 105 \equiv 18 \pmod{29}.##
This may look longer than what you did, however, it can be programmed and works always. At least for coprime numbers ##a,b.## Otherwise, we do not have an inverse.
Likes Delta2 and Math100
