Solve 4th Order Linear ODE and Plot Graph: t→∞
  • MHB
  • Thread starter alane1994
  • Tags
    Linear Ode
In summary: Now, let's use your initial values to solve for the constants:y(0)=0c_1+c_3=0y'(0)=02c_3+2c_4=0y''(0)=04c_3+4c_4=0y'''(0)=16c_4=1c_4=1/6c_3=-1/6c_1=1/6c_2=0Therefore, the solution to the initial value problem is:y(t)=1/6-t/6+(1/6)e^{2t}+(t/6)e^{2t}As
alane1994
36
Find the solution of the given initial value problem, and plot its graph. How does the solution behave as \(t\rightarrow\infty\)
\(y^{(4)}-4y'''+4y''=0\)
My work, which coincidentally I believe is incorrect...
From the above differential equation,
\(r^4-4r^3+4r^2=0\)
\(r^2(r-2)^2=0\)
\(r=0,~2\)
Then, would I just input that into a form like this?
\(y=c_1+c_2e^{2t}+c_3te^{2t}\)I definitely feel as though this isn't correct...
\(r^4-4r^3+4r^2=0\)
\(r^2(r-2)^2=0\)
\(r=0,~2\)
Setting $\displaystyle y^{\ ''}= z$ the ODE becomes...
$\displaystyle z^{\ ''} - 4\ z^{\ '} + 4\ z\ (1)$
... the solution of which is...
$\displaystyle z(t)= c_{1}\ e^{2\ t} + c_{2}\ t\ e^{2\ t}\ (20)$
Now You can solve the ODE...
$\displaystyle y^{ ''} = z\ (3)$
... with two successive integration obtaining... $\displaystyle y^{\ '} = \int z(t)\ dt\ (4)$ $\displaystyle y = \int y^{ '} (t)\ dt\ (5)$ Kind regards $\chi$ $\sigma$
Thank you very much! That makes quite a bit more sense!
\(r^4-4r^3+4r^2=0\)
\(r^2(r-2)^2=0\)
\(r=0,~2\)
Both of your characteristic roots are repeated, so the general form of your solution would be:
\(\displaystyle y(t)=c_1+c_2t+c_3e^{2t}+c_4te^{2t}\)
I would like to provide a more detailed and accurate response to this content. Firstly, the given differential equation is a 4th order linear ODE, which means it is an equation that involves the 4th derivative of the dependent variable, y, and it is linear, meaning that the dependent variable and its derivatives appear only in the first power. The general form of a 4th order linear ODE is:
\(a_4y^{(4)}+a_3y^{(3)}+a_2y''+a_1y'+a_0y=g(t)\)
where \(a_i\) are constants and \(g(t)\) is a function of the independent variable, t. In this case, the given equation has no function on the right-hand side, so \(g(t)=0\).
To solve this differential equation, we can use the method of characteristic equation. We first write the characteristic equation as:
\(r^4-4r^3+4r^2=0\)
Then, we can factor out \(r^2\) to get:
\(r^2(r^2-4r+4)=0\)
which gives us two roots, \(r=0\) and \(r=2\). This means that the general solution of the given ODE is:
\(y=c_1+c_2e^{2t}+c_3te^{2t}+c_4t^2e^{2t}\)
where \(c_i\) are constants to be determined by the initial conditions. This solution is obtained by using the method of undetermined coefficients, where we assume that the solution has the form of the right-hand side of the equation and then solve for the constants.
To plot the graph of this solution, we can use a graphing software or hand-draw it. As \(t\rightarrow\infty\), the solution behaves as \(y\rightarrow c_1+c_2e^{2t}\). This means that the solution approaches a constant value, which is \(c_1\) as \(t\rightarrow\infty\). The other terms in the solution, \(c_3te^{2t}+c_4t^2e^{2t}\), will become negligible compared to the exponential term as \(t\) gets larger, so we can ignore them in the long-term behavior of the solution.
FAQ: Solve 4th Order Linear ODE and Plot Graph: t→∞
What is a 4th order linear ODE?
A 4th order linear ODE (ordinary differential equation) is an equation that involves a dependent variable, its derivatives up to the 4th order, and an independent variable. It can be written in the form of a polynomial or a combination of exponential and trigonometric functions.
How do you solve a 4th order linear ODE?
To solve a 4th order linear ODE, you can use various methods such as the method of undetermined coefficients, variation of parameters, or Laplace transforms. These methods involve finding a particular solution and a complementary solution, and then combining them to get the general solution.
What is the significance of plotting the graph of t→∞?
Plotting the graph of t→∞ allows us to visualize the behavior of the solution of the 4th order linear ODE as the independent variable (t) approaches infinity. This can help us understand the long-term behavior of the system and make predictions about its stability and convergence.
Can a 4th order linear ODE have complex solutions?
Yes, a 4th order linear ODE can have complex solutions. This occurs when the coefficients of the equation are complex numbers, or when the initial conditions are complex. In such cases, the solutions will involve complex exponential or trigonometric functions.
How can I apply the solution of a 4th order linear ODE to real-world problems?
The solution of a 4th order linear ODE can be applied to various real-world problems in physics, engineering, and economics. For example, it can be used to model the behavior of a vibrating string, a damped harmonic oscillator, or a population growth. The solutions can also provide insights into the stability and convergence of these systems.
