Solve ## 4x+51y=9: x=15+51t, y=-1-4t ##
  • Thread starter Thread starter Math100
The Diophantine equation 4x + 51y = 9 is solved by first establishing that gcd(51, 4) = 1, allowing for the use of modular arithmetic. The congruence 4x ≡ 9 (mod 51) leads to the solution x ≡ 15 (mod 51), while 51y ≡ 9 (mod 4) gives y ≡ 3 (mod 4). This results in the general solutions x = 15 + 51t and y = -1 - 4t for integers t. A verification step confirms that these solutions satisfy the original equation. The discussion emphasizes the importance of checking the sufficiency of derived solutions in modular arithmetic.
Math100
Using congruences, solve the Diophantine equation below:
## 4x+51y=9 ##.
[Hint: ## 4x\equiv 9\pmod {51} ## gives ## x=15+51t ##, whereas ## 51y\equiv 9\pmod {4} ## gives ## y=3+4s ##. Find the relation between ## s ## and ## t ##.]
None.
Consider the Diophantine equation ## 4x+51y=9 ##.
Observe that ## gcd(51, 4)=1 ##.
Then ## 4x\equiv 9\pmod {51}\implies 52x\equiv 117\pmod {51}\implies x\equiv 15\pmod {51} ##.
Now we have ## 51y\equiv 9\pmod {4}\implies 3y\equiv 1\pmod {4}\implies y\equiv 3\pmod {4} ##.
This means ## x=15+51t ## and ## y=3+4s, \forall t, s ##.
Since ## 4(15+51t)+51(3+4s)=9 ##, it follows that ## s=-1-t ##.
Thus ## y=3+4s=3+4(-1-t)=-1-4t ##.
Therefore, ## x=15+51t ## and ## y=-1-4t, \forall t, s ##.
Math100 said:
Homework Statement:: Using congruences, solve the Diophantine equation below:
## 4x+51y=9 ##.
Relevant Equations:: None.
So far so good, except that you should toss the "s" in the last line since we only have one parameter ##t## left.
Theoretically, you must check whether your solution is actually one. You derived necessary conditions for your solution and got a set of possible solutions. Now, we check whether they are sufficient, too.
\begin{align*}
4x+51y= 9 &\Longleftrightarrow 4\cdot (15+51t)+51\cdot (-1-4t)=60-51=9
\end{align*}
This has - strictly speaking - always to be done if the steps of a calculation cannot be reversed, e.g. taking roots or squaring numbers, or if we use congruences. So either we could write ##\Longleftrightarrow ## along every step of a proof, or we deduce solutions and check whether they fulfill our requirement. The latter is usually easier to do.
Or notice 51=13(4)-1. From there, move terms ahead and multiply, for the first half. Then you can generalize to all solutions other than 4 , and choose one that is 15(Mod 51).
