Solve $(a^2-b^2)^2=1+16a$ for Integers
  • MHB
  • Thread starter anemone
  • Tags
    Integers
In summary, Dan's original equation had a wrong value for a and b and this caused problems when trying to find integer solutions. He was able to fix the problem by replacing a and b with their correct values.
anemone
MHB
POTW Director
3,883
115
Solve the equation in the set of integers:
$(a^2-b^2)^2=1+16a$
Mathematics news on Phys.org
$$(a^2-b^2)^2=1+16a$$
$$(a^2-b^2)^2-16a=1$$
$$(a^2-b^2-4\sqrt{a})(a^2-b^2+4\sqrt{a})=1$$
This implies that either both terms are 1, or both terms are negative 1. Trying for -1:
$$a^2-b^2-4\sqrt{a}=-1$$
$$a^2-b^2+4\sqrt{a}=-1$$
I'm not aware of any faster way of solving this, but let me know if there is :D
Add both equations:
$$2(a^2-b^2)=-2$$
$$(a+b)(a-b)=-1$$
This further implies that either both terms are negative, or both are positive. Solving both possible cases:
$a+b=1$
$a-b=-1$
and
$a+b=-1$
$a-b=1$
Gives us the integer solutions $(0, 1)$ and $(0, -1)$, respectively.
Add both equations:
$$2(a^2-b^2)=-2$$
$$(a+b)(a-b)=-1$$
$a+b=1$
$a-b=-1$
and
$a+b=-1$
$a-b=1$
Your proof does not follow because $a^2 - b^2 \pm 4 \sqrt{a}$ are not necessarily integers.
Add both equations:
$$2(a^2-b^2)=-2$$
$$(a+b)(a-b)=-1$$
$a+b=1$
$a-b=-1$
and
$a+b=-1$
$a-b=1$
Hi Rido12, (Wave)
Thanks for participating and Bacterius is right, I'm sorry that your solution doesn't work out to a full solution :( but I applaud you for attempting it. (Yes)
$(a^2-b^2)^2=1+16a$
[sp]I'm not going to write it out because it's all brute force and checking a lot of cases, but it can be done a modulo 4. If that's the only way I'll post, but I'd highly prefer a more elegant solution.)[/sp]
-Dan
-Dan
Thanks, topsquark for your reply. As far as I can tell, the modular arithmetic method isn't the only way to solve for this problem but I am willing to wait for a day or two before I posting the solution I've at hand, just in case there are other members who have still not thrown in the towel yet and determined to solve it using another approach. Okay?:)
(sighs) I ran into a hiccup.
I just went through the whole thing again to try and streamline it and I ran into a problem in my original work. I can whittle it down to two possibilities, \(\displaystyle a^2 \equiv 1,~b^2 \equiv 0~\text{mod(4)}\), which should clearly be not true, but proving it is nasty and frankly I don't know how to do it, or \(\displaystyle a^2 \equiv 0,~b^2 \equiv 1~\text{mod(4)}\), which clearly generates the two solutions, but proving that these are the only ones is nasty and here again I don't know how to do it. Without my mistake it was reasonably simple, if long. Ah well.
Back to square one I'm afraid.
-Dan
Addendum: Just thought I'd mention, my mistake was an easy one to make. Taking \(\displaystyle a^2 \equiv 1,~b^2 \equiv 0~\text{mod(4)}\) I originally took a = 2n + 1 and b = 2n. Of course, this isn't general. It should be a = 2n + 1 and b = 2m. When I fixed this and plugged the a = 2n + 1 into the original equation to find b(n) I got a horrible result for b which I don't know how to analyze in terms of integer solutions.
$(a^2-b^2)^2=1+16a--(1)$
from (1) we get :
$a\geq 0$
and $1+16a$ is a perfect square
if $a=0,\,\,b=\pm 1$
if $a>0:$
$a^2-b^2=c^2=\sqrt {16a+1}---(2)$
$a,b,c \in N$
now consder $a,b,c$ as 3 side length of a
right angled tiangle ABC,then
$a,c $ must be odd ,and $b$ even
let :$a=m^2+n^2,b=2mn, c=m^2-n^2--(3)$
from (2)(3)$m=\pm 2,\,\ n=\pm 1$
and we may conclude the corresponding solutions:
$(a,b)=(0,\pm 1),(5,\pm 4)$
Albert said:
from (1) we get :
$a\geq 0$
if $a>0:$
$a,b,c \in N$
this leaves out the possibility that
$a^2-b^2 = - c^2$
Solution of other:
It is evident that if $(a,\,b)$ is a solution of the equation, then $(a,\,-b)$ is also its solution. Hence, it's sufficient to consider $b \ge 0$.
Since the RHS is a non-negative, we could deduce that $1+16a\ge 0$. That is, $a$ takes positive integers value only. Therefore $(a^2-b^2)^2\ge 1$. This also implies $(a-b)^2 \ge 1$.
Hence, $(a^2-b^2)^2=(a+b)^2(a-b)^2\ge a^2 $.
From this we obtain the inequality $1+16a\ge a^2$. Solving this inequality gives $x\in \{0,\,1,\,\cdots,\,16\}$. In addition, $1+16a$ is a perfect square, we get $x\in \{0,\,3,\,5,\,14\}$. Only $x=0,\,5$ give integer value of $b$.
The solutions are hence $(0,\,1)$, $(0,\,-1)$, $(5,\,4)$ and $(5,\,-4)$.
FAQ: Solve $(a^2-b^2)^2=1+16a$ for Integers
What is the problem asking me to solve?
The problem is asking you to find all possible integer solutions for the equation $(a^2-b^2)^2=1+16a$.
How do I approach solving this type of equation?
This is a quadratic equation in terms of $a$, so you can use techniques for solving quadratic equations, such as factoring, completing the square, or using the quadratic formula. However, since the equation is in terms of $a^2$, you will need to take an extra step to solve for $a$.
Is there a specific method I should use to solve this equation?
There is no specific method that must be used, but it may be helpful to first simplify the equation by expanding the squared term and combining like terms. From there, you can use whichever method you are most comfortable with to solve for $a$.
Are there any restrictions or limitations to the solutions?
Yes, since the problem specifies that the solutions must be integers, you will need to make sure that the solutions you find are indeed integers. Additionally, there may be restrictions on the values of $a$ and $b$ based on the given equation.
What are some common mistakes to avoid when solving this equation?
Some common mistakes include forgetting to take the extra step to solve for $a$ after using a method for solving quadratic equations, making calculation errors when expanding or solving for $a$, and not considering all possible values for $a$ and $b$ that may satisfy the equation.
