Solve a trigonometric equation
In summary, the equation \cos^2 \left(\frac{\pi}{4}(\sin x+\sqrt{2}\cos^2 x)\right)-\tan^2 \left(x+\frac{\pi}{4}\tan^2 x\right)=1 can be solved by applying the Pythagorean Identity and setting one term to 1 and the other to 0. This results in the solution set x = 2nπ - π/4, where n is any integer.
anemone
MHB
POTW Director
3,883
115
Solve the equation
\(\displaystyle \cos^2 \left(\frac{\pi}{4}(\sin x+\sqrt{2}\cos^2 x)\right)-\tan^2 \left(x+\frac{\pi}{4}\tan^2 x\right)=1\)
Mathematics news on Phys.org
anemone said:
Solve the equation
I would probably start by moving the tangent function to the other side and applying the Pythagorean Identity to convert everything to cosines...
yeah there by it will become product of 2 cosine's =1 that means both equal to 1
People posting problems in this sub-forum are presumed to already have worked out the solution in full and are posting the problem as a challenge to others to solve rather than asking for help. (Wink)
anemone said:
Solve the equation
as cos^2 t < = 1 and tan ^2 a >= 0 so the 1st term is 1 and 2nd term is zero.
So cos^2(π/4(sinx+√2 cos2x)) = 1 and tan^2(x+π/4tan^2x) = 0
So (x+π/4tan^2 x) = n π , x = 0 is a solution and other solutions are
= n π – π/4(this I found by guessing tan ^2x =1 and not rigorously)
cos^2(π/4(sin x+√2cos^2x)) = 1 when x = 2 n π – π/4
hence this is the solution
FAQ: Solve a trigonometric equation
What is a trigonometric equation?
A trigonometric equation is an equation that contains trigonometric functions such as sine, cosine, or tangent. It involves finding the values of the variables that make the equation true.
How do I solve a trigonometric equation?
To solve a trigonometric equation, you need to use the properties and identities of trigonometric functions. You can also use algebraic manipulation and trigonometric identities to simplify the equation and find the values of the variables.
What are the common methods for solving trigonometric equations?
The most common methods for solving trigonometric equations are substitution, factoring, and the unit circle method. You can also use inverse trigonometric functions to solve equations involving trigonometric ratios.
What are the steps for solving a trigonometric equation?
The steps for solving a trigonometric equation are as follows:
1. Simplify the equation using trigonometric identities.
2. Use algebraic manipulation to isolate the variable.
3. Solve for the variable using one of the common methods.
4. Check your solutions by substituting them back into the original equation.
What are some tips for solving trigonometric equations?
Some tips for solving trigonometric equations are:
- Familiarize yourself with the properties and identities of trigonometric functions.
- Use the unit circle to help with solving equations involving trigonometric ratios.
- Check your solutions by substituting them back into the original equation.
- Practice solving different types of trigonometric equations to improve your skills.
