Solve A Trigonometric Equation
In summary, the conversation was about correcting a typo in the problem statement. The arguments on the left side of the equation should have been the same, with the second term being a sine function instead of a cosine function. The individual who caught the typo refrained from posting a solution as they had seen the problem before. Anemone expressed gratitude for the correction.
anemone
MHB
POTW Director
3,883
115
Solve
\(\displaystyle \sqrt{2}\cos \left(\frac{x}{5}-\frac{\pi}{12} \right)-\sqrt{6}\sin \left(\frac{x}{5}-\frac{\pi}{12} \right)=2\left(\sin \left(\frac{x}{5}-\frac{2\pi}{3} \right)-\sin \left(\frac{3x}{5}+\frac{\pi}{6} \right) \right)\)
Mathematics news on Phys.org
Did you want the arguments on both cosine terms to read the same?
I have edited anemone's post to correct the typo. She is offline now, but I am aware of the problem from another site, so I have taken the liberty to change the statement of the problem, and I will be refraining from posting a solution as I have seen the problem before.
The arguments on the left are supposed to be the same, however the second term was meant to be a sine function instead.
On behalf of anemone, I want to thank you for catching this! (Nod)
My solution:
By letting \(\displaystyle A=\frac{x}{5}-\frac{\pi}{12}\) use the sum-to-product formula to simplify the LHS of the equation, I get:
\(\displaystyle \sqrt{2}\cos A-\sqrt{6}\sin A=2\left(\sin \left(A-\frac{7\pi}{12} \right)-\sin \left(3A+\frac{5\pi}{12} \right) \right)\)
\(\displaystyle \sqrt{2}\cos A-\sqrt{6}\sin A=2\left(2\cos \left(2A-\frac{\pi}{12} \right)\sin \left(-A-\frac{\pi}{2} \right) \right)\)
\(\displaystyle \sqrt{2}\cos A-\sqrt{6}\sin A=-4\left(\cos \left(2A-\frac{\pi}{12} \right)\sin \left(A+\frac{\pi}{2} \right) \right)\)
\(\displaystyle \sqrt{2}\cos A-\sqrt{6}\sin A=-4 \left( \cos \left(2A-\frac{\pi}{12}\right)\right)\left( \cos A \right)\)
\(\displaystyle 4\cos A \left( \cos \left(2A-\frac{\pi}{12}\right)\right)=\sqrt{6}\sin A- \sqrt{2}\cos A\)
Now, divide the left and right side of the equation by \(\displaystyle \cos A\) and use the formulas for \(\displaystyle \cos 2A=\frac{1-\tan^2 A}{1-\tan^2 A}\) and \(\displaystyle \sin 2A=\frac{2\tan A}{1-\tan^2 A}\) to further simplify the equation yields:
\(\displaystyle \sqrt{6}\tan^3 A+\sqrt{6}\tan^2 A+(2\sqrt{2}-\sqrt{6})\tan A-(2\sqrt{2}+\sqrt{6})=0\) (*)
It's quite obvious that \(\displaystyle \tan A=1\) is one of the solution to (*) and use the long division to find the other two roots.
\(\displaystyle (\tan A-1)(\sqrt{6}\tan^2 A+2\sqrt{6}\tan A+2\sqrt{2}+\sqrt{6})=0\)
Since the discriminant of the quadratic expression that we found above is a negative value (\(\displaystyle -8\sqrt{12}\)), we can say the other two roots are imaginary roots.
Hence the solutions are
\(\displaystyle A=\frac{\pi}{4}+2n\pi\) where n is an integer, i.e.
\(\displaystyle \frac{x}{5}-\frac{\pi}{12}=\frac{\pi}{4}+2n\pi\) which gives us \(\displaystyle x=\frac{5\pi}{3}+10n\pi\).
To solve this trigonometric equation, we can use several methods such as the double angle formula, the sum and difference formula, or the product-to-sum formula. We can also use a graphing calculator to visualize the equation and find the solutions.
First, let's simplify the equation by using the double angle formula for sine and cosine:
\sqrt{2}\cos \left(\frac{x}{5}-\frac{\pi}{12} \right)-\sqrt{6}\sin \left(\frac{x}{5}-\frac{\pi}{12} \right)=2\left(2\sin \left(\frac{x}{5}\right)\cos\left(\frac{x}{5}-\frac{\pi}{4} \right)\right)
Next, we can use the sum and difference formula for sine to simplify the equation further:
\sqrt{2}\cos \left(\frac{x}{5}-\frac{\pi}{12} \right)-\sqrt{6}\sin \left(\frac{x}{5}-\frac{\pi}{12} \right)=2\left(2\sin \left(\frac{x}{5}\right)\cos\left(\frac{x}{5}\right)\cos\left(-\frac{\pi}{4} \right)-2\cos\left(\frac{x}{5}\right)\sin\left(\frac{x}{5}\right)\sin\left(-\frac{\pi}{4} \right)\right)
Simplifying further, we get:
\sqrt{2}\cos \left(\frac{x}{5}-\frac{\pi}{12} \right)-\sqrt{6}\sin \left(\frac{x}{5}-\frac{\pi}{12} \right)=4\sqrt{2}\sin\left(\frac{x}{5}\right)\cos\left(\frac{x}{5}\right)
Now, we can use the product-to-sum formula to simplify the equation even more:
\sqrt{2}\left(\cos\left(\frac{x}{5}\right)\cos\left(\frac{\pi}{12}\right)+\sin\left(\frac{x}{5}\right)\sin\left(\frac{\pi}{12}\right)\right)-\sqrt{6}\left(\sin\left(\frac{x}{5}\right)\cos\left(\frac{\pi}{12}\right)-\cos\left(\
FAQ: Solve A Trigonometric Equation
How do I solve a trigonometric equation?
To solve a trigonometric equation, you must first identify the type of equation (sine, cosine, tangent, etc.). Then, use trigonometric identities and algebraic techniques to manipulate the equation into a form where you can isolate the variable. Finally, use inverse trigonometric functions to solve for the variable.
What are the common trigonometric identities used in solving equations?
Some common trigonometric identities used in solving equations include the Pythagorean identities (sin²x + cos²x = 1), sum and difference identities (sin(A ± B) = sinAcosB ± cosAsinB), and double angle identities (sin2x = 2sinxcosx).
Can I use a calculator to solve a trigonometric equation?
While a calculator can help you check your solutions, it is not recommended to solely rely on a calculator to solve a trigonometric equation. It is important to understand the concepts and processes involved in solving the equation manually.
Are there any special cases to consider when solving a trigonometric equation?
Yes, there are special cases to consider when solving a trigonometric equation. These include equations with multiple solutions, equations with restricted domains, and equations with extraneous solutions (solutions that do not satisfy the original equation).
How can I check if my solution to a trigonometric equation is correct?
You can check your solution by substituting it back into the original equation and seeing if it satisfies the equation. You can also graph both sides of the equation and see if they intersect at the solution point.
