Solve a trigonometric equation
In summary, the conversation involved solving for $y$ when given the equation $\tan 4y=\dfrac{\cos y-\sin y}{\cos y +\sin y}$ and the restriction that $y$ must be in radians and between $0$ and $\dfrac{\pi}{4}$. The solution involved using the formula $\tan(a-b)=\dfrac{\tan(a)-\tan(b)}{1+\tan(a)\tan(b)}$ with $a=\dfrac{\pi}{4}$ and $b=y$. This formula was not something that had to be memorized, but was instead derived from basic trigonometric identities.
anemone
MHB
POTW Director
3,883
115
Let $y$ be in radians and $0<y<\dfrac{\pi}{4}$.
Solve for $y $ if $\tan 4y=\dfrac{\cos y-\sin y}{\cos y +\sin y}$.
Mathematics news on Phys.org
We can rewrite the RHS as:
$$\tan 4y=\frac{1-\tan y}{1+\tan y}=\tan\left(\frac{\pi}{4}-y\right)$$
$$\Rightarrow 4y=n\pi+\frac{\pi}{4}-y$$
Only n=0 gives a solution in the specified range, hence
$$y=\frac{\pi}{20}$$
Pranav said:
$$\frac{1-\tan y}{1+\tan y}=\tan\left(\frac{\pi}{4}-y\right)$$
How did you get that?
It's not something you had to learn by heart did you? :rolleyes:
Nope. :D
I used the following formula:
$$\tan(a-b)=\frac{\tan(a)-\tan(b)}{1+\tan(a)\tan(b)}$$
with $a=\pi/4$ and $b=y$. :)
To solve this trigonometric equation, we can start by simplifying the right side of the equation using trigonometric identities. We can rewrite the numerator as $\cos y - \sin y = \cos y \left(1 - \tan y\right)$ and the denominator as $\cos y + \sin y = \cos y \left(1 + \tan y\right)$. Substituting these into the original equation, we get:
$\tan 4y = \dfrac{\cos y \left(1 - \tan y\right)}{\cos y \left(1 + \tan y\right)}$
Next, we can simplify the equation by dividing both sides by $\cos y$:
$\tan 4y = \dfrac{1 - \tan y}{1 + \tan y}$
We can then use the double angle formula for tangent, $\tan 2\theta = \dfrac{2\tan \theta}{1-\tan^2 \theta}$, to rewrite the equation as:
$\tan 4y = \tan 2y$
Since $0<y<\dfrac{\pi}{4}$, we know that $0<2y<\dfrac{\pi}{2}$, which means that the tangent function has a one-to-one correspondence in this interval. Therefore, we can set the arguments of the tangent functions equal to each other:
$4y = 2y$
Solving for $y$, we get $y=0$. However, this solution does not satisfy the given interval of $0<y<\dfrac{\pi}{4}$. Therefore, there is no solution for $y$ that satisfies the given equation within the given interval. This can also be seen by graphing the two sides of the equation, which do not intersect within the given interval.
FAQ: Solve a trigonometric equation
What is a trigonometric equation?
A trigonometric equation is an equation that involves trigonometric functions, such as sine, cosine, tangent, etc. The goal is to find the value(s) of the variables that make the equation true.
How do I solve a trigonometric equation?
There are various methods to solve a trigonometric equation, depending on the type of equation. Some common methods include using trigonometric identities, factoring, and substitution. It is important to follow the order of operations and simplify the equation as much as possible before solving for the variables.
What are the common trigonometric identities used to solve equations?
Some of the most commonly used trigonometric identities include the Pythagorean identities, reciprocal identities, and double angle identities. These identities can be used to simplify complex trigonometric expressions and solve equations.
Do I need to use a calculator to solve a trigonometric equation?
It depends on the complexity of the equation. For simple equations, a calculator may not be necessary. However, for more complex equations, a calculator may be helpful in finding the approximate values of the variables.
Can a trigonometric equation have multiple solutions?
Yes, a trigonometric equation can have multiple solutions. This is because trigonometric functions are periodic, meaning they repeat their values after a certain interval. Therefore, there may be more than one value of the variable that satisfies the equation.
