MHB Solve Algebra Quadratics: Get Solutions & Answers
  • Thread starter Thread starter leads
    Algebra
The discussion focuses on solving algebraic quadratic equations related to two cars traveling on perpendicular roads and the properties of parabolas. The first problem involves deriving the distance formula between the two cars and finding their closest distance using the Pythagorean theorem. The second problem requires determining the value of k for a parabola whose vertex lies on the x-axis and finding the equation of a second parabola that intersects with the first. Key methods include using vertex formulas and substituting values to derive equations. The thread emphasizes understanding the solutions rather than just obtaining answers.
leads
Hi all,
Son came home with these questions and is unable to solve them.
I am also struggling with these questions. I need to explain to my son how to get the solutions and not just the answers.
Any help would be greatly appreciated!
1. Two cars are traveling along two straight roads which are perpendicular to each other and meet at the point O.
The first car starts 50km west of O and travels east at a constant speed of 20km/h.
The second car starts 30km south of O at the same time and travels north at a constant speed of 15km/h.
a)Show that at time t, the distance d between the two cars satisfies:
d^2 = 625t^2 - 2900t + 3400
B) Hence find the closest distance between the two cars.2. a) The graph of y =x^2 - 6x + k has its vertex on the x axis. Find the value of k.
b) A second parabola has its vertex at (-2, 5) and passes through the vertex of the first graph. Find the equation of the second graph in the form y = ax^2 + bx + c
c) Find the co-ordinates of the other point of intersection between the two graphs.Many thanks!
Mathematics news on Phys.org
Express the distance of each car to the intersection point as a function of $t$, then use the Pythagorean theorem, which expresses the hypotenuse through sides: $c^2=a^2+b^2$.
The vertex of the parabola $ax^2+bx+c$ has $x$ coordinate $-\frac{b}{2a}$. Calculate the value of the parabola at this point.
Again, find the $x$ coordinate of the vertex, substitute it into $x^2 - 6x + k$ and equate to 0 (since the vertex has $y$ coordinate equal to 0).
All parabolas with vertex $(x_0,y_0)$ have equation $a(x-x_0)^2+y_0$ for some $a$. Use the fact that the parabola passes through the vertex of $y =x^2 - 6x + k$ you found in the previous question to find $a$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
