Solve [ASK] Limit of Cosine: How to?
In summary, the limit \lim_{x\rightarrow\frac{\pi}{2}}\frac{\cos{x}}{x-\frac{\pi}{2}} can be solved by using the substitution u=\frac{\pi}{2}-x and applying the co-function identity \cos\left(\frac{\pi}{2}-\theta\right)=\sin(\theta). This leads to an indeterminate form of \frac{0}{0}, but it can be solved using the well-known limit \lim_{x\to0}\left(\frac{\sin(x)}{x}\right)=1.
Monoxdifly
MHB
284
How to solve \(\displaystyle \lim_{x\rightarrow\frac{\pi}{2}}\frac{\cos{x}}{x-\frac{\pi}{2}}\)? At first I tried to convert cos x to \(\displaystyle \frac{\tan{x}}{\sin{x}}\) but then realized that \(\displaystyle \lim_{x\rightarrow c}\frac{\tan{x}}{x}\) only applies if c = 0. So, how?
Mathematics news on Phys.org
Let's use the substitution:
\(\displaystyle u=\frac{\pi}{2}-x\)
What does the limit become then?
\(\displaystyle \lim_{u\rightarrow0}\frac{\cos{(\frac{\pi}{2}-u)}}{-u}\)?
Yes, and so I would factor the negative sign in the denominator out in front of the limit, and apply a co-function identity to the numerator...(Thinking)
Won't it give \(\displaystyle \frac{0}{0}\) again in the \(\displaystyle \frac{\cos{\frac{\pi}{2}}\cdot\cos{u}}{u}\) part?
Recall the co-function identity:
\(\displaystyle \cos\left(\frac{\pi}{2}-\theta\right)=\sin(\theta)\)
And so our limit becomes:
\(\displaystyle L=-\lim_{u\to0}\left(\frac{\sin(u)}{u}\right)\)
And yes, this is an indeterminate form, but it is well-known to students and usually allowed as a result to use:
\(\displaystyle \lim_{x\to0}\left(\frac{\sin(x)}{x}\right)=1\)
Oops... Sorry sorry... Totally forgot about that...
Consider the following diagram of the unit circle in the first quadrant:
From this, we can see that for $0\le x\le\dfrac{\pi}{2}$ we have:
\(\displaystyle \sin(x)\le x\le\tan(x)\)
Dividing though by $\sin(x)$, we obtain:
\(\displaystyle 1\le\frac{x}{\sin(x)}\le\frac{1}{\cos(x)}\)
or:
\(\displaystyle \cos(x)\le\frac{\sin(x)}{x}\le1\)
And so we must then have:
\(\displaystyle \lim_{x\to0}\left(\cos(x)\right)\le\lim_{x\to0}\left(\frac{\sin(x)}{x}\right)\le\lim_{x\to0}(1)\)
or:
\(\displaystyle 1\le\lim_{x\to0}\left(\frac{\sin(x)}{x}\right)\le1\)
Hence (by the squeeze theorem):
FAQ: Solve [ASK] Limit of Cosine: How to?
What is the limit of cosine?
The limit of cosine is the value that the cosine function approaches as the input approaches a certain value. In other words, it is the value that the cosine function approaches as the input gets closer and closer to a specific number.
How do you solve for the limit of cosine?
To solve for the limit of cosine, you can use the limit definition of cosine or use the properties of limits to simplify the expression. You can also use L'Hospital's rule or trigonometric identities to evaluate the limit.
Can the limit of cosine be undefined?
Yes, the limit of cosine can be undefined. This occurs when the input approaches a value for which the cosine function is not defined, such as infinity or a point where the function has a vertical asymptote.
What is the difference between the limit of cosine and the value of cosine at a specific point?
The limit of cosine is the value that the function approaches as the input gets closer and closer to a specific value. On the other hand, the value of cosine at a specific point is the output of the function when the input is equal to that specific value.
Why is it important to know the limit of cosine?
Knowing the limit of cosine can help in understanding the behavior of the function near a specific value. It can also be used to evaluate complicated trigonometric expressions and to find the derivatives of trigonometric functions.
