Solve Bounded $u_t=u_xx$ Let $u_t=u_xx,\,t>0,\,x\in\mathbb R$
  • MHB
  • Thread starter Markov2
  • Tags
    Bounded
In summary, we are given the partial differential equation $u_t=u_xx,\,t>0,\,x\in\mathbb R$ with the initial condition $u(x,0)=xe^{-|x|}.$ By applying the Fourier transform, we obtain the representation formula for $u(x,t)$ as $\frac{1}{\sqrt{4\pi t} } \int_{\mathbb{R}} e^{\frac{(x-y)^2}{4t}}g(y)dy$, where $g(y)$ is the Fourier transform of the initial condition. Using Hölder's inequality, we can show that $|u(x,t)|\leq \frac{1}{\sqrt{4\
Markov2
149
Let $u_t=u_xx,\,t>0,\,x\in\mathbb R$ and $u(x,0)=xe^{-|x|}.$ Show that $|u(x,t)|\le \dfrac K{\sqrt t}$ for all $t>0$ and $x\in\mathbb R$ where $K$ is a constant.
So I apply Fourier transform, then $\mathcal F(u_t)=\mathcal F(u_xx)$ then $\dfrac{{\partial \mathcal F(u)(w,t)}}{{\partial t}} = - {w^2}\mathcal F(u)(w,t)$ so $\mathcal F(u)(w,t)=ce^{-w^2t}$ then $\mathcal F(u)(w,0)=c=xe^{-|x|},$ is the initial condition well put? I'm not sure really, I'm confused.
Since you have a representation formula for \(u\), everything's easier. You have
$$u(x,t)= \frac{1}{\sqrt{4\pi t} } \int_{\mathbb{R}} e^{\frac{(x-y)^2}{4t}}g(y)dy$$
This gives, using Hölder's inequality with \(p=1, p'=\infty\)
$$|u(x,t)|\leq \frac{1}{\sqrt{4\pi t} } \int_{\mathbb{R}} |g(y)|dy$$
since \(\sup_x e^{\frac{(x)^2}{4t}} = 1\) for all \(t>0\).
Could you please show me how did you find $u(x,t)$ ? I'm stuck on the initial condition, don't know if I did it right, can you check?
I won't write out everything, since apparently my definition of the Fourier transform is different (non-essentially though) from yours. You should arrive at an equation of the form \(\hat{u}_t (x,t)= c(x)\hat{u}\) (\(c(x)\) will depend on your definition of the transform) with the initial condition \(u(x,0)=\hat{f}(x)\) (where \(f\) is your initial condition). This has a solution given by \(\hat{u}(x,t)=\hat{f}(x) e^{c(x)t}\). Put the exponential as the Fourier transform of someone and apply the result that says the transform of a convolution is the product of the transforms along with the inversion theorem. This should give you my formula.
Yes, your approach is correct. Applying Fourier transform to the PDE gives $\frac{\partial \mathcal{F}(u)}{\partial t} = -w^2\mathcal{F}(u)$, which has the solution $\mathcal{F}(u)(w,t) = ce^{-w^2t}$. Plugging in the initial condition $\mathcal{F}(u)(w,0) = c = xe^{-|x|}$, we get $\mathcal{F}(u)(w,t) = xe^{-|x|}e^{-w^2t}$.
To find the constant $K$, we can use the fact that the Fourier transform is a unitary operator, meaning it preserves the $L^2$ norm. So we have $\|u(x,t)\|_{L^2} = \|\mathcal{F}(u)(w,t)\|_{L^2}$. Using the Parseval's identity, we have
$$\|u(x,t)\|_{L^2} = \|\mathcal{F}(u)(w,t)\|_{L^2} = \left(\int_{-\infty}^{\infty}|\mathcal{F}(u)(w,t)|^2dw\right)^{1/2} = \left(\int_{-\infty}^{\infty}|xe^{-|x|}e^{-w^2t}|^2dw\right)^{1/2} = \|xe^{-|x|}\|_{L^2}.$$
Using the fact that $\|xe^{-|x|}\|_{L^2} = \sqrt{\frac{2}{\pi}}$, we have $\|u(x,t)\|_{L^2} = \sqrt{\frac{2}{\pi}}$. Therefore, we can choose $K = \sqrt{\frac{2}{\pi}}$ and we have $|u(x,t)| \leq \frac{K}{\sqrt{t}}$ for all $t>0$ and $x\in\mathbb{R}$, as required.
FAQ: Solve Bounded $u_t=u_xx$ Let $u_t=u_xx,\,t>0,\,x\in\mathbb R$
How do you solve a bounded $u_t=u_xx$ equation?
The first step in solving this equation is to separate the variables by assuming that the solution is of the form $u(x,t)=X(x)T(t)$. This will allow us to rewrite the equation as $\frac{T'(t)}{T(t)}=\frac{X''(x)}{X(x)}$. Next, we can use the separation of variables method to solve for $X(x)$ and $T(t)$ separately. Finally, we can use boundary conditions and initial conditions to determine the constants in the solution and obtain the final solution for $u(x,t)$.
What is a bounded solution?
A bounded solution is one in which the values of the function remain within a finite range, even as the independent variables change. In the context of a partial differential equation like $u_t=u_xx$, a bounded solution means that the function $u(x,t)$ does not grow infinitely large or approach negative infinity as $x$ and $t$ increase.
Can you explain the significance of the boundedness condition in this equation?
The boundedness condition is important because it ensures that the solution to the equation remains physically meaningful. In other words, a bounded solution means that the values of the function do not become unrealistically large or small, which could happen if the equation did not have this constraint.
How does the solution to $u_t=u_xx$ change if the boundedness condition is not satisfied?
If the boundedness condition is not satisfied, then the solution to the equation will become unbounded, meaning that the values of the function will either grow infinitely large or approach negative infinity as $x$ and $t$ increase. This can lead to unrealistic or physically impossible solutions, making the equation invalid.
Are there any other factors that can affect the solution to $u_t=u_xx$?
Yes, there are other factors that can affect the solution to this equation, such as the initial conditions and boundary conditions. These conditions determine the values of the constants in the solution and can significantly alter the behavior of the function over time. Additionally, the choice of method used to solve the equation can also impact the resulting solution.
