MHB Solve by separation of variables
find_the_fun
Solve given differential equation by separation of variables
[math]\frac{dy}{dx}=\frac{xy+3x-y-3}{xy-2x+4y-8}[/math]
So separate x and y terms
[math](xy-2x+4y-8) dy = (xy+3x-y-3)[/math] ugh I'm stuck:(
Re: solve by separation of variables
You want to factor the numerator and denominator of the right side, then you may separate variables.
I can factor to [math]\frac{dy}{dx}=\frac{(x-1)(y+3)}{(x+4)(y-2)}[/math] and rewriting gives [math]\frac{(y-2)}{(y+3)} dy = \frac{(x-1)}{(x+4)} dx[/math]. Am I on the right track? I don't know how to integrate this.
Yes, you are correct. For the left side, consider:
$$\frac{y-2}{y+3}=\frac{y+3-5}{y+3}=1-\frac{5}{y+3}$$
Do the same kind of thing on the right side, and you should be able to integrate now.
Is an alternative to [math]\frac{y+3-5}{y+3}[/math] doing polynomial division and seeing y+3 goes into y-2 once with a remainder of 5? I'm not super clear on the thought process of getting [math]1-\frac{5}{y+3}$$.
find_the_fun said:
Is an alternative to [math]\frac{y+3-5}{y+3}[/math] doing polynomial division and seeing y+3 goes into y-2 once with a remainder of 5? I'm not super clear on the thought process of getting [math]1-\frac{5}{y+3}[/math].
Yes, although the remainder is actually -5, but then you get the same result. I just find it simpler to do as I did above. To make what I did more clear, consider:
$$\frac{y-2}{y+3}=\frac{(y+3)+(-2-3)}{y+3}=\frac{y+3}{y+3}-\frac{5}{y+3}=1-\frac{5}{y+3}$$
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
